Golf mk2
5th injector tomfoolery
Topic: 5th injector tomfoolery (Read 2678 times)
Dizzie
Forum addict
Make friends with your fast
28 February 2004, 16:15 »
I disconected my 5th injector after reading what was said on here and now I'm getting a good 8mpg more than I was getting previously
Since my exhaust started to blow I'd stuggle to get it over 30mpg and now it's up in the 37's all the time. weirdness.
I think my injectors are leaking making my starts bad.
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
mk1
2ltr16v turbo (now with programmable EFI)
Re:5th injector tomfoolery
28 February 2004, 17:03 »
Hey, result
. Prob slight leak from the injectors.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
Dizzie
Forum addict
28 February 2004, 17:28 »
that's what I was thinking. I'm guessing the cold start valve isn't work properly and the 5th injector was on all the time using more fuel.
it still starts fine, if not better now.
turbo
Guest
28 February 2004, 23:47 »
if its leaking try some fuel system treatment that should sort the injectors out...
Veedubgt18v
Guest
29 February 2004, 18:39 »
dizzie is yours kjet or digi? what do i remove? fifth injector??
Dizzie
Forum addict
29 February 2004, 19:30 »
kjet. don't remove it!
just unplug it!
I've now for the ISV disconnected aswell. it was reving up and down a lot on tickover and pissing everyone off. now ticks over at 700rpm. stalls now and then if you're not carefull though.
Ciaran
GTI forum regular
Reply #6 on:
29 February 2004, 22:55 »
is it still as fast with that done?
cos why would they fit it if it did nowt?
Golf mk2
