Whats the point in having an R32 then apart from getting a nice noise in a tunnel?
Very wet roads apparently.
And personally I really like the seats.
However, couldn't justify the extra dosh over my GTi
Luckily for me my R32 cost me less than a Gti would (leased) so Im more than happy to have a car worth £5k more than the standard Gti.
I personally don't know how you worked that out! Someone at the stealer must have c0cked up the figures somewhere.
For me the R32 sounds better,
I don't think anyone is doubting that a standard R32 sounds better than a standard GTI or Ed30.
handles better, and no doubt in the wet would leave most 2WD's for spray.
Then sadly, you are misguided. Every single published test on the R32 states that handles worse than the GTI. As for wet traction, a reasonably competent driver would achieve nigh-on identical wet traction with the GTI and R32. For general wet handling, particularly cornering, 4 wheel drive makes absolutley NO difference.
Agreed that as Hurdy said the stats are not always correct as he found on his runs.
I think Hurdys experience merely backs up what has already been stated in all the journo reports.
But I really do belive your getting a better, more composed car. No real back up for this statement, thats just how it feels.
Why do you think that. The interior is identical to the GTI, save for a different aluminuim trim, and different colour needles. The handling is actually worse than the GTI, and the ride comfort is much worse than the GTI. Oh, and the boot is considerably smaller than the GTI, which is pretty important if it is your only means of transport.
It is probably just a "placebo" effect - you have bought a more expensive car, so you naturally "think" that it must be better than its' sibling minnows!
Ask anyone who has driven or owned both cars. As for that crap about understeer!!!
Erm, I HAVE driven the two (R32 manual, and GTI manual on 18"s) side by side, on the same day, in identical weather conditions, on the same Michelin Pilot Exalto PE2 tyres. When pushed to the limits, the GTI remains neutral, but the R32 DOES understeer - quite a lot!
Add power and there is no such thing as understeer, the power shifts to the back, and anywhere you point the thing it goes.
Two things, if you are getting understeer on zero or trailing throttle, then you arn't diving properly. Secondly, if you claim that by adding power and "remove" the understeer, then you are no-where near the limit. I suggest you find some private facilities, where you can "explore", in safety, the limits of your car.
Furthermore, your claim that "power shifts to the back" clearly demonstrates the poor dynamics of the R32 Haldex part-time four wheel drive system.
