Author Topic: MK2 tweeter position  (Read 2837 times)
VeeDubGTI16v
« on: 26 February 2004, 10:38 »
where do you reckon tweeters should go in a mk2 at the front??
i had them in the original speaker location in the back corners of the dash but you can hardly hear them :P
the less cutting the better too ;D
Offline Dizzie
  • Make friends with your fast
Re:MK2 tweeter position
« Reply #1 on: 26 February 2004, 11:25 »
Where the window handles would be if you have leccy windows.
Mk4 Golf 150PD
Offline techno_hippy
« Reply #2 on: 26 February 2004, 19:20 »
On a small bracket (you may have to make one) on the outside corners of the underdash tray, you can use the screw that bolts the tray up to the dash, Very neat and excellent sound.  A bit of alloy sheet cut to a strip and bent to about 90 deg will do, you can then angle and rotate to adjust sound.  Its the next best thing to kick pannel pods...   No cutting required!! :)
Offline lowgolf
« Reply #3 on: 27 February 2004, 18:33 »
I agree with dizzie. In the manual window blanks
<br /><br />Yeah!!!
