Author Topic: lower ball joint pinch bolt  (Read 1335 times)
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« on: 27 August 2007, 12:25 »
Whats ythe tightening process for this?
Is it as tight as you can get by hand when its in the air, then finally tourque it when its on the ground, or is all tightening go on when the wheels are on the ground?
cheers.
Offline golf8v
Re: lower ball joint pinch bolt
« Reply #1 on: 27 August 2007, 19:22 »
do it up tight in the air.. dont need to be done in lowered position. thats only for bolts like the on the arm which have a bush in centre hopes this helps :shocked:
Offline Simon8v91
« Reply #2 on: 27 August 2007, 19:23 »
Torque it up whenever you like.
I thought it was usually bolts that go through bushes that it was good practice to fully torque with wheels on the ground to ensure they are properly seated and so as not to put an unusual stress in the bush and cause premature wear.
Offline Mew
« Reply #3 on: 27 August 2007, 19:58 »
cheers.
Do it the opposite way to last time!  :wink:
Offline Simon8v91
« Reply #4 on: 27 August 2007, 20:13 »
Do tell!  :grin:
Offline Mew
« Reply #5 on: 27 August 2007, 20:50 »
I'll leave it to Chris to explain.
I'm pretty sure it was to do with this anyway......
