Author Topic: audi 80 sport brake setup...  (Read 3593 times)
Offline dabill
« on: 26 August 2007, 10:59 »
howdie!
made a trip to the local breakers yesterday, and found a rather minted example of an audi 80 sport in bright red and perfect condition... couldnt find a single thing wrong with it so im guessing internals to the engine were fubar...
anyhoo, took the interior door release handles which i'll post up later(look much better) and had a good scout around.
noticed the brakes. are the ones on the automatic 280mm ones cos they looked huuuge! if so, im guessing thhat they will bolt straight upto my 8v digi... is this true?
rob
oh yeah, if anyone wants anything of it then give me a shout... didnt have the vdo guages in or the sensors though...
noble tuned - and still not fast enough!
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: audi 80 sport brake setup...
« Reply #1 on: 26 August 2007, 13:33 »
You'll need the hubs along with the calipers and carriers to bolt up to an 8v. Have a look at the calipers, cos they are potentially girling 60's on these cars (i could be wrong), if they are, they will be twin piston bad boys (ansd worth quite a bit).
You'll also be wanting a 22mm master cylinder.
Offline Gambit
« Reply #2 on: 27 August 2007, 10:09 »
girling G60 calipers are not the twin piston ones. they are single piston
the calipers & carriers of the audi will fit up to your golf. the hubs will not, you will still need to find a set of late golf 16v hubs in order to run the 280mm setup
and yes replace the master cylinder with either a late 16v or vr6 item
Offline dabill
« Reply #3 on: 27 August 2007, 11:06 »
so i'll need to get a 16v golf hub setup, and master cylinder... could i not use the mastercylinder off the audi?
if not, how much are the master cylinders for the 16v?
cheers
rob
Offline Chris-White
« Reply #4 on: 27 August 2007, 11:23 »
Offline Gambit
« Reply #5 on: 27 August 2007, 11:24 »
i wouldnt be using a 2nd hand master cylinder out of a scrapper EVER.
they are about £40 new from GSF & ECP etc
or check ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110127893081
Offline Gambit
« Reply #6 on: 27 August 2007, 11:27 »
they look twin piston to me  :wink:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=300143290518&rd=1
the Girling 60's on mine are single piston, so unless they changed design at a certain date?!?!
Offline dabill
« Reply #7 on: 27 August 2007, 13:09 »
well, i'll go up and have a looky, will see what they are.
need to go back cos i've now found out my gear knob has been put on very tight and rounded off so i cant get the bloody thing off...so gotta get some gear components.
isnt mk2 maintenence super fun!
Offline richard s
« Reply #8 on: 27 August 2007, 20:48 »
where is the audi being broken
Offline dabill
« Reply #9 on: 29 August 2007, 12:52 »
sorry richard, only just noticed your post!
car is located at wilf jays! near the morrisons off the parkway.
they have loads a VAG cars as i have now found out, has become my new home!
