Author Topic: INlet manifold?  (Read 3028 times)
Offline GavG60
  • keep my credit cards away from me please :-(
INlet manifold?
« on: 25 February 2004, 13:28 »
I have a mk2 16v, the inlet manifold on it is from a SEAT. is this normal? I have just bought a 50mm VW manifold to replace it, as i like it to all be VW.
Would the SEAT one be a modification? or a scrap yard replacement?
G :-\
Offline mk1
Re:INlet manifold?
« Reply #1 on: 25 February 2004, 19:28 »
Check the engine code stamped on the engine block, should be a "KR" engine. The upper part of the manifold could have been changed for a Seat one as they use a similar engine (what size is it and what throttle body?). 50mm is the way to go on a 16v.
Steve.
Offline modulater
Re:INlet manifold?
« Reply #2 on: 25 February 2004, 21:26 »
The seat one is the same style as the MK3 16V one.
golfvr6
Re:INlet manifold?
« Reply #3 on: 25 February 2004, 21:28 »
Thats correct the 16v engine in the seat ibiza is the ABF engine.
Offline modulater
Re:INlet manifold?
« Reply #4 on: 25 February 2004, 21:31 »
Indeed
Offline mk1
Re:INlet manifold?
« Reply #5 on: 25 February 2004, 21:47 »
My reason for the throttle body question ;).
Offline GavG60
Re:INlet manifold?
« Reply #6 on: 26 February 2004, 09:40 »
Cool, thanks for the info, will check it out.
Stupid question, where will I find the stamp on the block? ;D
VeeDubGTI16v
Re:INlet manifold?
« Reply #7 on: 26 February 2004, 10:27 »
has anyone put the 50mm inlet manifold on instead of the 42mm one?
what difference does it make ???
Offline GavG60
Re:INlet manifold?
« Reply #8 on: 26 February 2004, 12:03 »
and how do you tell the difference between the 50mm and 42mm? is it written on it? if not what do you measure?????  ???
Offline GavG60
Re:INlet manifold?
« Reply #9 on: 27 February 2004, 14:51 »
err....I've just read on a different forum that the 42mm manifolds were better for performance?
Anyway, just bought a 2nd hand one from www.findapart.co.uk for ?45
then walked into Volkspares and got sold another one for ?15......
like buses.....  ;D
