Author Topic: fitting and induction kit or panel filter  (Read 2089 times)
Offline TRANTER
  • golf mkII gti 8v
« on: 21 August 2007, 21:23 »
hi all im new to this i have a 1.8 gti 8v k-jet engine and wondering if i can fit an iduction kit if so which ones best and how or any pics of other peoples cheers is it the f.i.p ontop of the airbox cheers all carl
Offline nealey
Re: fitting and induction kit or panel filter
« Reply #1 on: 21 August 2007, 21:58 »
induction kit is a waste of time and money imo,
Offline EsSeX dAn
« Reply #2 on: 21 August 2007, 22:05 »
if you want induction kit ggo for the bmc sealed unit or the pipercross viper.both of theese use a dedicated cold feed so only the air that goes in the cold air tube gets in the engine saving any heat soak
i think i love you.....
Offline MarkS
« Reply #3 on: 22 August 2007, 01:51 »
Yeah, those two are supposed to be the best induction kits, however they are costly.
A replacement panel filter is meant to do just the trick and its over £100 less :smiley:
I think Green are pretty well respected panels?
That was my choice  :cool:
Waiting for it to arrive  :wink:
Offline gibby
« Reply #4 on: 22 August 2007, 08:10 »
Just get a K&N panel filter and save your money from the induction kit. If you're after an induction roar then just drill your airbox, wing side.
......now officially dubless.
Offline dabill
« Reply #5 on: 22 August 2007, 08:58 »
i just got a big peice of flexi tube and tiewrapped it onto the grill and then put a k&N cone filter and hooked the cold feed upto that... looks smart too suprisingly, and does the trick, however im deffo going back to original box and a panel filter when i decide i can be bothred.
rob
noble tuned - and still not fast enough!
Offline gti south
« Reply #6 on: 23 August 2007, 15:53 »
i fitted an induction kit when i got my digi 8v couple months bk the airbox was drilled before with performace panel dont know which one and its the same.............. :undecided:
Gti 8v not bad for a first car
Offline Gambit
« Reply #7 on: 23 August 2007, 17:24 »
just get a panel filter
if u do want an induction kit then u need a special induction kit as ur car is kjet, its made by PiperCross.
Offline Ben Lessani
« Reply #8 on: 24 August 2007, 08:29 »
Stick with a panel filter, it has the same effect. Make sure if you drill the box you do it beneath the air filter! I've got a K&N fitted in mine and you notice the inductiony noise (with std non-drilled airbox) and if saves the expense of buying a new filter every service.
Offline gibby
« Reply #9 on: 24 August 2007, 09:11 »
I've given this example before, but Vaughn (global mod) on here has a brother who until recently had the biggest BHP Audi S3 in the country and all he was running was a panel filter, now he'd changed all sorts on the S3 to get the power it was up to and he did loads of research before doing anything and if an induction kit would have made a big difference he'd have had one, he knew it wouldn't, so he didn't. :wink:
There endeth the lesson. :laugh:
