Author Topic: does anybody know???  (Read 1514 times)
Offline Seth
« on: 21 August 2007, 15:19 »
does anybody know if the antiroll bars off a gti will fit straight onto a driver
AKA VEEDUBJUNKY
Offline DarnPB
  • Formerly Darnpistonbroke
Re: does anybody know???
« Reply #1 on: 21 August 2007, 15:32 »
They should do. They are the same car but the driver has a less powerfull engine. Suspension, trim and everything else to my knowledge is the same.
Offline Gambit
« Reply #2 on: 21 August 2007, 17:35 »
yeah they will fit no probs
Offline Seth
« Reply #3 on: 22 August 2007, 09:41 »
what about the brakes and suspention Its a 1.6 not a 1.8
AKA VEEDUBJUNKY
Offline DarnPB
« Reply #4 on: 22 August 2007, 11:04 »
Still the same. The driver was a poor mans GTI. GTI without the GTI performance. I think everything is interchangeable bar engine components and ancilliaries.
Brakes, trim, interior, running gear etc.
Offline Seth
« Reply #5 on: 22 August 2007, 11:16 »
brakes and handling are crap
AKA VEEDUBJUNKY
Offline DarnPB
« Reply #6 on: 22 August 2007, 12:21 »
As long as you use 15'' wheels, you can use the braking equipment from a G60. You will need the front hubs and the master cylinder too. As for handling, your shocks may be a little tyred. You can always upgrade when you replace but if upgrading, buy matching sets of springs and shocks. You WILL notice the difference.
Offline Seth
« Reply #7 on: 22 August 2007, 13:39 »
could I use the front disks and calipers from a 16 valve?
AKA VEEDUBJUNKY
Offline kkh120
« Reply #8 on: 22 August 2007, 14:42 »
To use the calipers and discs from a 16v I think you need to change the hubs. I dont know if the driver will take the 8v barkes and discs without the hub change?
Mk2 8v and 16v.
Always looking for bits!
Offline Seth
« Reply #9 on: 22 August 2007, 14:49 »
I was thinking just to the complete front end running gear off a valver and change the lot hubs,disks,calipers,suspension and anti roll bar
AKA VEEDUBJUNKY
