Golf mk2
Engine rattle on start
Topic: Engine rattle on start (Read 3768 times)
Ceptor
24 February 2004, 09:24 »
Can anyone help me with a new and annoying problem? I've done a search but couldn't find anything similar.
My engine is the 1.6 carb and on start from cold there is a loud rattle from the left (o/s) of the engine which dies away after a few minutes - although it's still there but quieter.
Could it be the cam belt? I know it needs changing soon anyway - 100,000 miles on the original.
golfvr6
Guest
Re:Engine rattle on start
24 February 2004, 10:48 »
Do you mean the timing belt end?
Could be the tensioner, try taking the cover off, and have a listen.
If it is then get it done straight away.
Ceptor
24 February 2004, 11:17 »
Yes it is the timing belt end, there is quite a loud non metallic rattle from that area on cold start which then dies off after say one minute.
I'll have a look asap. If it is the timing belt what should I replace in addition to the belt and tensioner? What special tools will I need?
golfvr6
Guest
24 February 2004, 11:32 »
change the timing belt,tensioner and v belt.
no special tools are required, however it is a lot easier to tension the belt with the proper vw tensioning tool.
Ceptor
24 February 2004, 11:46 »
Where can I get this tensioning tool and any idea as to cost?
golfvr6
Guest
24 February 2004, 14:06 »
i think its
www.sptools.com
, costs about 10 quid.
Ceptor
Reply #6 on:
24 February 2004, 14:17 »
Thanks. I will also be doing the timing belt on my 1984 Audi 100 5-cylinder engine soon can you recommend a similar website I could read which covers the Audi range?
golfvr6
Guest
Reply #7 on:
24 February 2004, 14:21 »
I think the 5 cylinder Audi engines, have the timing belt on the water pump type, same as early smaller engine golfs and polos, ie. 1.0 and 1.3.
Ceptor
Reply #8 on:
24 February 2004, 14:39 »
Ah yes I see that now.
The descriptions in the Haynes manuals look very similar. I was just hoping that I could change the Audi timing belt without having to remove the vibration damper on the end of the crankshaft, fitted with 258 lb ft...
golfvr6
Guest
Reply #9 on:
24 February 2004, 15:47 »
The vibration damper is not fitted to that torque, thats the crankshaft bolt. The vibration damper (or pulley) should come off with the smaller allen key bolts, same as a golf.
Golf mk2
