Author Topic: Rear calliper  (Read 907 times)
Offline Dolly
Rear calliper
« on: 12 August 2007, 20:05 »
My handbrake is proper crap and i suspect its the callipers.. im just wandering apart from mk2 rear callipers which others fit.. mk3..mk4.. if others fit do hubs need to be changed and all that malarkie. just wandering what my options are really. any help appreciated..
P.S im just going out so thats why i havent searched  :laugh: :kiss:
Offline Dolly
Re: Rear calliper
« Reply #1 on: 12 August 2007, 20:10 »
Did a quick search lol... mk4 alloy callipers ey... the only thing i see about them is its mentioned about the flexi hose. would i need to get some made up lenght and union wise.. or can mk4 hoses be used? .. i assume rear pads and discs are the same across mk2/3/4 ... also any mk4 with rear discs right?
Offline Mr Blue
Re: Rear calliper
« Reply #2 on: 12 August 2007, 20:17 »
just mk3 'em :wink:
Offline richard s
Re: Rear calliper
« Reply #3 on: 12 August 2007, 21:34 »
aparently mk4 are just alloy versions of mk3 with a different hose attachment but you can get hose adapter to fit mk4 calipers
Offline Dolly
Re: Rear calliper
« Reply #4 on: 12 August 2007, 22:32 »
the quick search i did seems to say that the mk4 alloy ones have a different h/brake arrangment and dont seize up like mk2's... i know a place that makes braided hoses, a few quid per hose is it just a case of getting a braided hose thats the same length as the mk2 standard hose with a different end for the mk4 calliper?
Offline Dolly
Re: Rear calliper
« Reply #5 on: 12 August 2007, 22:48 »
Searched again.. the same h/brake cables on late mk2's, mk3's and mk4's so can use my current one...all hoses appear to be the same length from the rear beam but mk4's use a banjo bolt connection so need to get a couple of mk4 hoses or just take a mk2 flexi to this place know and get them copied, braided and with different ends on. lick of hammerite jobs a good one by the looks of it  :smiley:
Offline Gambit
Re: Rear calliper
« Reply #6 on: 12 August 2007, 23:21 »
C&R Enterprises will supply you the correct hoses to fit mk4 calipers
http://www.candrenterprises.co.uk/
Offline Dolly
Re: Rear calliper
« Reply #7 on: 13 August 2007, 19:15 »
Just emailed them cheers for the link. Callipers are in the post, so here goes   :tongue:
