Author Topic: wanting to fit a rev counter to my 1.3!  (Read 2270 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: wanting to fit a rev counter to my 1.3!
« Reply #10 on: 12 August 2007, 19:34 »
it may be, i know john rubjonny did it on his driver that way.. he might be able to tell you if there is anything need done wiring wise inside the clocks.. i think there is 1 lead or something, ill have to check what he said..
otherwise to transplant them its a case of unplug and plug in.. not forgetting the speedo vac as well..
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
« Reply #11 on: 12 August 2007, 19:37 »
27/07/2007  15:41:56  rubjonny  speedo is just a few screws in teh back
27/07/2007  15:42:09  rubjonny  theres a leccy plug going to oil pressure circuit
27/07/2007  15:42:14  rubjonny  swappy
27/07/2007  15:43:43  rubjonny  basically the pcb at the back has a jumper plug type thing
27/07/2007  15:43:51  rubjonny  goes thru clocks into oil pressure circuit
27/07/2007  15:44:01  rubjonny  bit o gente persuasion and it pops off
27/07/2007  15:44:15  rubjonny  if i were you id popp the pressure circuit off the speedo and swap as well
27/07/2007  15:44:24  rubjonny  keep it with the same clocks if you get me
Quote
Offline vwjack
« Reply #12 on: 12 August 2007, 22:43 »
thanks buh. kinda know what i need 2 do now.
Offline dubsport
  • TDI POWAR!
« Reply #13 on: 13 August 2007, 10:28 »
ok sorry just want to make sure i understand :) take out the old clocks, put in clocks with rev counter and thats it?
Offline vwjack
« Reply #14 on: 14 August 2007, 14:16 »
so there is no rev counter wiring it all there in my 1.3?
« Reply #15 on: 14 August 2007, 14:51 »
it sure is and ive jsut done it  :smiley:
dubsport: yep basically - thats if you find some close to yours like..
the key thing to also check for is the series of 4 numbers below KM/H thats denotes the gearing, these also need to match - again a good route if you cant find a set with the same gearing but a counter is to transplant as i have done..
pics coming shortly
Quote
« Reply #16 on: 14 August 2007, 15:03 »
Picture story until I can be assed to write anything about it  :grin:
Quote
Offline dubsport
  • TDI POWAR!
« Reply #17 on: 14 August 2007, 18:42 »
wicked, thanks for the pics Matt ... might give that a go :D
Offline vwjack
« Reply #18 on: 14 August 2007, 19:34 »
thanks for the help matt.
