Author Topic: wanting to fit a rev counter to my 1.3!  (Read 2265 times)
Offline vwjack
« on: 11 August 2007, 22:21 »
hello. as you see i want too try and fit a rev counter to my 1.3. what will i need and what do i need to do.
thanks guys
Offline 8vRicey
  • Silver Mettalic 8v GTI
Re: wanting to fit a rev counter to my 1.3!
« Reply #1 on: 12 August 2007, 10:33 »
Swap it in for a GTI !!  :grin: :grin:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #2 on: 12 August 2007, 10:51 »
this is a current experiment of mine
you can either directly swap the clocks with a milage close to yours, make sure you get the right set, the 1 or 2 pins..
or my route im taking is to swap the speedo and milometer into a set with a rev counter ready fitted and fit them, retaining the factory and original speedo to my car..
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline dubsport
  • TDI POWAR!
« Reply #3 on: 12 August 2007, 12:27 »
 :huh:
good luck with that, im confused just reading it hehe  :smiley:
Offline vwjack
« Reply #4 on: 12 August 2007, 13:53 »
haha i would like to.hmm i think im just going to swap the clock for the rev counter. do you know what pin i would need for a 1.3.
« Reply #5 on: 12 August 2007, 17:19 »
pre 90spec - 2 pin, post - 1 pin clocks..
Quote
Offline vwjack
« Reply #6 on: 12 August 2007, 17:53 »
sorry mate blonde moment here. i have a h reg but shes a 1990.  :embarassed:
« Reply #7 on: 12 August 2007, 18:15 »
will be a single pin set of clocks youre after then..
check ebay or a scrappy, you can get a set of clocks that just drop in as long as they are the 1 pin type, to match.. unless you wanna go the same route as me but if youre not too confident i wouldnt risk it - like i wont do my cambelt  :grin:
Quote
« Reply #8 on: 12 August 2007, 18:16 »
 :huh:
hehehe..
open original set of clocks from car, open the casing, unscrew and remove the dial that has the milage on, and the speedo, disconnect any other connections to it, open second set of clocsk, ones featuring rev counter, remove speedo from this second set, refit original speedo from original clocks, reassemble  :smiley:
Quote
Offline vwjack
« Reply #9 on: 12 August 2007, 19:14 »
is it as easy as that what about wireing . thanks for the help.
