Author Topic: 1.9 8v gti wont idle but will rev passted 2000rpm  (Read 1067 times)
Offline danboisgolf
hi there iv got a 1.9 8v gti convirsion done to my mk2 had it done some time ago an then left it stud due to not enought funding to carrie the project on now iv gone back to it. it dose not seem to idle but once it gets pass 2000rpm it seems fine iv changed the injection pipes because they were corroded and i also chected for air leaks and didint find any if anyone has had this sort ov problem an could help it would be graitfull cheers danny.
Offline dabill
Re: 1.9 8v gti wont idle but will rev passted 2000rpm
« Reply #1 on: 07 August 2007, 14:12 »
was it running before you left it?
noble tuned - and still not fast enough!
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 07 August 2007, 14:17 »
Check all the connections are ok and free from corrosion. Then check the blue sensor and change as a matter of course. Then check that the idle stabalizer valve is working. It should vibrate when the ignition is on.
Offline Gambit
« Reply #3 on: 07 August 2007, 14:20 »
sounds more like the timing is not set correctly
Offline danboisgolf
« Reply #4 on: 07 August 2007, 17:41 »
when i left the vehicle it was running spot on it dint miss a beat it started 1st turn ov the key just would not idle.
