Author Topic: best speakers to fit into dash near windscreen?  (Read 1668 times)
Offline Simpson
  • one day il learn
« on: 01 August 2007, 21:22 »
as aboe can you not get some really good speakers to fit perfectly from chavfords? for a mark 2? do Sony not do some? i have alwasy found it a bit tinny from the door pods, maybe its just the sh!tty jbl compnants i have or the fact they are not amped? cheers
i must buy a new car!
Offline tommk3cab
Re: best speakers to fit into dash near windscreen?
« Reply #1 on: 01 August 2007, 21:53 »
what exactly are you looking for? JBL coaxes ( i assume, not componants?!) should be doing you fine unless they are severely underpowered from the HU or if they are wired wrongly.
aftermarket speakers should always be amped if they are half decent.
you say they sound tinny, why do you want to do your dash speakers, they will if anything make your system more tinny ( definately not bassier anyway!)
JBL are good, you wont get better for the money thats for sure.
Offline Simpson
  • one day il learn
« Reply #2 on: 02 August 2007, 12:14 »
ok then i need to amp then possible, they are compnoents with crossovers just there never seems enough sound from the front unless i really turn them up, thanks  :smiley:
Offline tommk3cab
« Reply #3 on: 03 August 2007, 12:30 »
yeah, that makes sense now! its probably because you are expecting them to be low bassy, they wont be when used with crossovers, thats the reason for crossovers, they cut out the very low bass notes, some of which the speaker can produce if used without crossovers, but it is better of not doing so!
speakers without crossovers will produce all of the spectrum of sound which they physically can but it is not best for performance.
They will be producing the best sound quality they can, especially when they are amped.
amp them properly and you will notice a very big increase in quality and (mid) bass response.
The misunderstanding with aftermarket HU's is that they increase the power to a point where you need to replace the speakers, this is not usually the case, HU's are ment to be a stand alone upgrade, by this I mean, use with stock speakers and you should notice a boost in quality ( unless the stock speakers are very bad or in an old car)
aftermarket speakers are another level all together and HU amps are not powerful enough (in general) to drive them.
like I said in my above post though make sure the + and - are the right way around or this will cause you serious problems, its hard to tell your exact problem without hearing it.
It will be one of those 2 things though and there is an easy way to tell if the + and - are the wrong way round if your unsure but dont want to remove the speakers just to check. (ill tell you if you are unsure.)
to sum up! ( sorry to go on!) I would get an amp depending on your componant set, If you want some advice on what amp then post a link to your componants, let me know a budget, and ill have a look around.
« Last Edit: 03 August 2007, 12:33 by tommk3cab »
