Author Topic: front speaker amp earthing  (Read 1650 times)
Offline jammac
« on: 29 July 2007, 09:13 »
i want to amp up my front door component speakers as my HU doesnt give them what they want! im unsure as to where to site an amp and earthing screws are probably an issue i need to consider.
could anyone tell me where there is an easily accessible earthing screw i can earth my amp lead to?
i will probably mount it under the shelf below the glove box. or in the glovebox itself.
cheers
j
ITS A TRAP!
Offline dubslug
Re: front speaker amp earthing
« Reply #1 on: 29 July 2007, 12:29 »
if u have a mk there is an earthing block just under the steering wheel, take off lower dash bit and u should see it easuily enough, just one place i can think off
1992 pearl grey 8v
Offline tommk3cab
« Reply #2 on: 29 July 2007, 16:41 »
or handbreak or bonnet release catch. there is always a few places, just wire it all up and leave the earth until the end and then find a place that works.
just make sure its clean metal and it should be fine. try and get it to be on like a main part of the car, like the earthing block metioned above ( if you have one?!) or the handbrake, rather than like through a panel or a welded joint or something.
