Looked at the manual which comes with the car yesterday evening and it says when the cars ignition is turned on, the battery light should come on as well as the oil light and coolant gauge light.The oil light should go of as well as the coolant light after about two or three flashes and the battery light once the car has been started.The problem is that the battery light dosnt come on at all when I put the key in the ignition and I know for certain that it did until I did some work last night.The first thing I did was remove the old radio.I didnt replace it with a new one yet and the wires are just trailing on the dash.Could it be that there is a wire coming from the battery to the radio and as it is not connected ,the battery light in the dash does not work or is it something more serious.I also removed the foglight switch and replaced it with a new one,maybe I disturbed some wires???
