Author Topic: ABS warning light tomfoolery!  (Read 1186 times)
Offline richyrooney
« on: 26 July 2007, 21:42 »
Hello again think tank!......Had trouble with my abs light coming on when i bought my car a couple of months ago but seemed to cure itself and went out and has stayed out....until this morning when the b*stard has come back on again.Plan to manually check the sensors with a multi-meter this weekend but in the mean time just had a question?When i turn on the ignition and start the car the ABS light comes on and then as usual goes out after a couple of seconds and stays out until i get to around about 15-20mph when it comes on, does this mean it is definately a wheel sensor? or could it be the deadly expensive pump? Would have thought pump fault would make light stay on all the time?.....any advice as always is greatly appreciated cheers!
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: ABS warning light tomfoolery!
« Reply #1 on: 26 July 2007, 22:33 »
Nope a pump fualt can cause the ABS light to come on intermitantly, i had this with mine but in the end had to change the pump and a rear sensor-that sorted it once and for all God willing. Cost me £160 for a second hand pump supply+fitting at Midland VW.
Offline bulk66
  • Im broke an it aint a joke!!!!
« Reply #2 on: 28 July 2007, 00:41 »
Just had to have a ABS sensor on the VR and the light stayed on all the time ... :smiley: Cost £50 quid in total with labour....
Offline richyrooney
« Reply #3 on: 28 July 2007, 09:34 »
cheers guys will test sensors for resistance and AC current generation with my borrowed multimeter this weekend and let you know.Just  hope its a sensor as i would rather change all four than have to cough up for the "demon" pump unit!
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 28 July 2007, 11:59 »
Could be worth getting the codes read and erased.... as any old codes will be stored until either the ecu is reset or the codes cleared.
Offline richyrooney
« Reply #5 on: 28 July 2007, 14:50 »
Can you reset the ABS ECU in the same way as the engine ECU by disconnecting the battery?
