Author Topic: Awesome APR remap  (Read 2252 times)
Offline jonathonturner
Awesome APR remap
« on: 26 July 2007, 11:45 »
having collected my car on tuesday and driving it back to manchester from milton keynes, i took it straight there and they put the 6 hr trial in the car...
some difference!!
however, it was damp and the car spins up real easy, even dry there is now an element of torque steer, the car in standard form is pretty quick to say the least, so should i map it permanent? or just add a good exhaust to the standard car....
its booked in for next wednesday so your thoughts are apprectiated.
thanks
Jt
Offline Creepy Coupe
Re: Awesome APR remap
« Reply #1 on: 26 July 2007, 11:47 »
Might get a bit tiresome if you had it full time, maybe something a little more user friendly.
Offline Hurdy
« Reply #2 on: 26 July 2007, 14:57 »
The standard GTI after being remapped by Awesome GTI is about the same (speed wise) as the ED30. I should know as I went up against their demo model at GTI International. Their best 0-60 was exactly the same as mine(5.66 secs) and in the standing 1/4 mile there was only 7 hundredths of a second in it. Not bad consideing the Awesome GTI car has all the bells and whistles fitted and mine is standard :wink:
I can live with mine easily in the wet, damp or dry, so if you like it, go for it.
There are other remap specialists out there, but I'm assuming you are close to Awesome and it will be easier for you...yes? You could also think about Superchips Bluefin as that is reversible and can be done over the internet without the need for you to go to a supplier. A word of caution though. The diverter valve is a weak link and easily blows and so some have opted for a forge DV upgrade at around £150.
Hope this helps. :cool:
Seat Leon Cupra Black 290 DSG
Offline gazbutmk5gti
« Reply #3 on: 26 July 2007, 22:20 »
I've had APR remap both stage 1 and 2, and its one of the most proggresive maps you can get, currently running stage 2 with a few other mods and making  262bhp and 330ft/lbs and its still really driveable. The traction control sorts everything out in the wet and in the dry it really is a quick car and I've shocked quite a few of the more desirable sports cars particularly on the motorway where the torque really counts, Awesome have done most of the work on my last few cars and I can't recommend them enough.
Revo stg2+ & lots more
« Reply #4 on: 27 July 2007, 08:31 »
coolio..gaz, what suspension are you running? and how doe sit drive compared to stock...
ta
Jt
Offline Rob-MK5
« Reply #5 on: 27 July 2007, 10:28 »
I think im tempted with going Awesome for the APR,
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #6 on: 27 July 2007, 12:43 »
It's worth remembering, the throttle isn't a switch and allows infinite degrees of progress.
If the car's torque steering or spinning it's wheels when wet, then you may have to use a little less throttle until you're rolling at a quick enough pace for it not to happen. Denying yourself more power seems a little daft if the OP just needs to re-calibrate his throttle modulation...
The greatest leveller of them all - the Carousel
Offline bmx
« Reply #7 on: 27 July 2007, 18:12 »
what he said  :wink:
my ed30 is bluefined and 307bhp, i have no problems with torque steer at all
« Reply #8 on: 27 July 2007, 18:54 »
ta
Jt
I'm using eibach dampers and springs and eibach anti-roll bars front and rear, I tried koni FSD's but found them to be to much of a compromise, I wanted a sporty ride with handling improvements.
I have never had a problem with torque steer either
