Author Topic: sunroof motor  (Read 2527 times)
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: sunroof motor
« Reply #10 on: 03 September 2007, 19:06 »
can i pay you to make me one me bomp  :grin: ill psot you the bits to do it with, jsut need it done, then  :wink:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline bomp
Re: sunroof motor
« Reply #11 on: 03 September 2007, 20:34 »
what wires were there to power it?
All i have is a thick blue and thick black that are joined side by side.
is that right?
Yeah, one will be the -ve (Clamp it to ground/chassis) and the other will be +ve (Use a 12v +ve wire when ignition/key is switched to on) with the motor switch (to open/close) inbetween.
Send me the manual winder cover, but it might take a while as I'm quite busy. I'll PM you.
« Last Edit: 15 June 2011, 14:19 by bomp »
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline monkeyalan
Re: sunroof motor
« Reply #12 on: 03 September 2007, 20:51 »
thought that might be the case but electrics really are my weak point.  :rolleyes:
Re: sunroof motor
« Reply #13 on: 03 September 2007, 20:52 »
wwciekd got your pm, but, as the message is ehre, how lnog do you reckon it would take approx? and, i was gonig to put the switch in next to the interior light, or at least possibly hoped to, if i chipped out the hole ready, can you trim it to that?  :wink:
Quote
Offline bomp
Re: sunroof motor
« Reply #14 on: 03 September 2007, 21:10 »
Should be ok, but only if there's enough clearance with the switch and the motor. You'll have to take a look at where the best place for switch is to be placed I guess.
Length of time.........? Dunno really, a week or two? not sure.
« Last Edit: 15 June 2011, 14:17 by bomp »
Re: sunroof motor
« Reply #15 on: 03 September 2007, 22:04 »
week or 2 would be sound thought you meant like a month or 2  :laugh:
Quote
