Author Topic: sunroof motor  (Read 2520 times)
Offline monkeyalan
sunroof motor
« on: 24 July 2007, 11:47 »
picking up my new 16v later but it has no motor for the steel sunroof.
s the motor mk2 specific or do other motors fit, eg mk3 golf?
cheers.
Offline bomp
Re: sunroof motor
« Reply #1 on: 24 July 2007, 12:02 »
I believe Audi 80's are a direct fit.
Corrrado motor might fit also.
« Last Edit: 15 June 2011, 14:09 by bomp »
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline monkeyalan
Re: sunroof motor
« Reply #2 on: 24 July 2007, 12:45 »
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: sunroof motor
« Reply #3 on: 24 July 2007, 13:47 »
I believe Audi 80's are a direct fit, but I used a pug 405 GL motor myself, and had to do some fiddling to get it to fit.
Corrrado motor should fit also.
did that require cutting that evil bit of metal sticking out? the audi 80 one I believe you do have to chop off some random bit of metal - which isnt any use and wont stop you reverting back to the original setup.. r something?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline bomp
Re: sunroof motor
« Reply #4 on: 24 July 2007, 14:11 »
Yeah, the pug one needs some ally filed down just wide of the screw holes so it sits flush.
« Last Edit: 15 June 2011, 14:12 by bomp »
Offline monkeyalan
Re: sunroof motor
« Reply #5 on: 02 September 2007, 19:32 »
will a corrado one fit?
Offline bomp
Re: sunroof motor
« Reply #6 on: 02 September 2007, 22:35 »
I would have thought that it would be a straight on fit, just grab it if you can get it, and do a how to with pics.
Re: sunroof motor
« Reply #7 on: 03 September 2007, 07:54 »
bomp - how did you make the motor cover, i've been trying to do one myself but it just aint happening, did you use jsut like cream material, rather than matching maTERIAL? THE ONLY STUFF I COULD GET TO USE WAS A SUNVISOR, CUT DOWN TO GIVE ME SOME OF THE MATERIAL, BUT ITS QUITE THICK AND  doesnt fit too well, and has a crease line all the way through..  :sad:
oops slipped caps in the middle there without realising  :grin:
Quote
Offline bomp
Re: sunroof motor
« Reply #8 on: 03 September 2007, 11:26 »
Use roof lining as the cover.
« Last Edit: 15 June 2011, 14:14 by bomp »
Offline monkeyalan
Re: sunroof motor
« Reply #9 on: 03 September 2007, 16:55 »
what wires were there to power it?
All i have is a thick blue and thick black that are joined side by side.
is that right?
