Car audio
JVC KD-AR5500 (touchscreen)
Topic: JVC KD-AR5500 (touchscreen) (Read 2903 times)
Golf_Spunce
20 July 2007, 12:52 »
Not sure if any1 else has this HU, but every time I leave car (switch off and lock) it loses all my settings!!! (including cusotm EQ-ing etc etc)
Anyone got any ideas......would be SO appreciated
Pic of HU (
http://akamaipix.crutchfield.com/ca/reviews/2005/0512/5500.jpg
Mike
R98 HUF
Guest
Re: JVC KD-AR5500 (touchscreen)
20 July 2007, 12:55 »
Guessing from previous experience you have the two mems back to front (yellow and red wires i believe i know with Vauxhall you need to wire them the opposite way, 1 does permanent memory Ie what u are loosing and i does temproary ie when engine on
Golf_Spunce
20 July 2007, 14:27 »
cheers mate, i didn't hardwire it in, was using a harness....any ideas?
KINGS>
Here all the time
Watch out for the guns.....
20 July 2007, 14:31 »
as already mentioned the red and yellow are the wrong way round... you have to alter them on the h unit harness before installation, they should be on male and female connectors it should take 5 mins
Golf_Spunce
20 July 2007, 15:51 »
you saying cut it out of harness and hard wire?
Ashmond
Money, b!tches And Boost
20 July 2007, 16:44 »
I got this headunit and had this problem for ages, and whenever you turn it on you have to hear the b!tch go "menu, mode...etc" you need to plug in the remote wire at the back, i just took it to halfrauds and they did it within two secs
KINGS>
Here all the time
Reply #6 on:
21 July 2007, 00:05 »
it is not the remote at fault... the remote is a low voltage switch feed for amps and electric aerials etc.. take out the headunit and identify two wires one red the other yellow, these will be located directly behind the h/unit in its harness.. you will see they have male and female connectors already in place this is to allow you to alter the harness in accordance to your vehicle, all you have to do is switch round the yellow and red so on the harness you have red coming out of the radio then connecting to a yellow on the iso multi plug and vice versa for the yellow..
tommk3cab
Reply #7 on:
21 July 2007, 00:33 »
na, you wont have to use wire clippers. the red and yellow wires have a bullet clip configuration block so you can switch or join them, like mentioned above it will take only seconds to do once the stereo is out.
Car audio
