Author Topic: Weighted Shift Rod  (Read 2898 times)
Offline gjroe78
Weighted Shift Rod
« on: 18 July 2007, 14:51 »
Is a weighted shift rod worth fitting ???
As i'm gonna strip the gearbox down, now is the time to decide i reckon
Has anyone got one ??? I know rubjonny has
And what about a Neuspeed Shortshift kit ???
Cheers Guy's N Gal's
« Last Edit: 18 July 2007, 14:54 by gjroe78 »
Offline Gambit
Re: Weighted Shift Rod
« Reply #1 on: 18 July 2007, 16:40 »
just get the one from VAG, £11+vat, and money worth spending
Offline tobz.
« Reply #2 on: 18 July 2007, 17:29 »
Yep they make gear changes feel much smoother and a lot more positive. Money well spent I would say.
You got any pics of your dad's split ?
Offline sesterfield
« Reply #3 on: 18 July 2007, 18:06 »
second  :smiley:
Offline 8vRicey
  • Silver Mettalic 8v GTI
« Reply #4 on: 18 July 2007, 20:09 »
Awesome paired with a short-shift too !!  :laugh: :laugh:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline nealey
« Reply #5 on: 18 July 2007, 22:30 »
Not all short shifts fit with the weighted shift rod though i believe unless you do some trimming of the shift rod first
Offline dabill
« Reply #6 on: 19 July 2007, 16:31 »
i know this might be a silly question, but how does a short shif mech work exactly? and are they easy to fit, becuase im considering the weighted shift rod, but if the short shift is easy to fit then might do that :laugh:
rob
noble tuned - and still not fast enough!
Offline moonsta
« Reply #7 on: 19 July 2007, 17:16 »
 if you have access to a welder you can make your own, all you do is mark the flat angled bit of the shifter,cut approx 1" out of it with an angle grinder and weld it back together again.if you have doubts about your welding get someone compitent to do it and weld it both sided,grind it flat and re-paint it.
 if you do that and fit the weighted shift rod and the poly bush that matey sells at the top of this page,you will have fab gearchange..........
Drives '96 Polo 6N and '85 Mk Golf Gti...
Offline herbster
« Reply #8 on: 19 July 2007, 21:13 »
 :smiley:
I made mine myself! Used a 1" CAT bolt with the head and thread chopped off, drilled into both ends, two bits of plain 1/4" bar with a 90' bend on the ends welded them in at required angles, jobs a good one!!  :grin:
 :smiley:
FAB is my life and the CABRIO's the wifes!!!!
Offline rowlers
  • I'm back - MK7 GTI
« Reply #9 on: 19 July 2007, 21:26 »
http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml
have a look there.
I can get you the short shift made if you want. I have one and its fab!
