Author Topic: ESP  (Read 4110 times)
Offline gib6107
ESP
« on: 18 July 2007, 09:19 »
I was told that if you hold the ESP button down for a few seconds it disengages completely i.e. there are 2 stages, the first only turns it off partially. Doesn't seem to work on mine (TDI150 03 reg) Has anyone else heard this?
cheers!
Offline Rhyso
Re: ESP
« Reply #1 on: 18 July 2007, 09:37 »
haven't to be honest; its either on or off!
Offline Ridg
  • TDI - Soot Happens!
Re: ESP
« Reply #2 on: 18 July 2007, 09:38 »
I've never heard of that, the button should be a toggle eg if its on you have no light on the instrument panel, if its off the light is lit constantly.
Offline gooseuk
  • Diesel is the way forward
Re: ESP
« Reply #3 on: 18 July 2007, 17:05 »
On mine you press it and it goes off. Press it again and it comes back on.
Simple
Diesel power all the way
Offline gsn1978
Re: ESP
« Reply #4 on: 03 August 2007, 09:57 »
Thats fair enough but if you are being an arse and the car is being dogged and driven poorly it will switch its self back on with you putting it on... i think thats what the original post means however i am not sure if it goes off compleatly.... crack on.... :laugh:
Cheers, George.... 1.8 GTIt and loving it!!
Offline Ridg
Re: ESP
« Reply #5 on: 03 August 2007, 10:06 »
if that is the case sort of defeats the point of having an off switch doesn't it.
Offline Rhyso
Re: ESP
« Reply #6 on: 03 August 2007, 10:38 »
it does and more annoyingly means it's like the system on Mercs which is never fully disabled  :sad:
What kind of a world are we living in where OFF doesn't mean OFF!!??  :laugh:
Offline Red_Stafford
Re: ESP
« Reply #7 on: 20 September 2007, 08:38 »
Whats the ESP actually do ?
Offline Rhyso
Re: ESP
« Reply #8 on: 20 September 2007, 08:46 »
it monitors your speed, steering angle, etc and if it thinks you're going to fast will back off the power, apply the brakes etc.
basically it will try and help stop you getting into difficulty but it won't prevent a crash
Ridge gave a pretty good explanation a few weeks back; have a search through the main board and have a look
Offline Ridg
Re: ESP
« Reply #9 on: 20 September 2007, 09:15 »
From the Audi site
Quote
The electronic stabilisation program (ESP) makes the vehicle easier to control in handling situations close to the limit It reduces the danger of swerving and thus improves directional stability. ESP identifies the car's intended direction and response. It applies the brakes on individual wheels, thereby generating one-sided forces that help to keep the car moving in the desired direction. The program uses the anti-lock braking system (ABS), electronic brake-force distribution (EBD), the electronic differential lock (EDL) and the traction control (ASR) system, and is permanently active.
The latest version, ESP 8.0 also offers a dry brake function: in adverse weather conditions, the system wipes water off the brake discs at regular intervals by applying the brake pads. This process goes unnoticed by the driver and reduces the stopping distance in wet weather compared with conventional brake systems.
Note:
ESP cannot override a car's physical limits. If a driver pushes the possibilities of the car's chassis and ESP too far, ESP cannot prevent an accident.
