Author Topic: Noisy 150 TDI  (Read 17371 times)
Offline gib6107
Noisy 150 TDI
« on: 18 July 2007, 09:17 »
Does anyone know how noisy/quiet a TDI150 engine should be? I've driven diesels (other makes) before but I expected this one to be quieter than it actually is. Seems to give off a 'tappet-like' noise when accelerating. Nothing extreme, I just wondered whether this is normal.
cheers!
Offline Rhyso
Re: Noisy 150 TDI
« Reply #1 on: 18 July 2007, 09:37 »
depends on which gear you are in; if you're in a high gear but low speed then sometimes it can make a bit of a racket lol
have you checked your oil level to make sure thats ok?
Offline Ridg
  • TDI - Soot Happens!
Re: Noisy 150 TDI
« Reply #2 on: 18 July 2007, 09:40 »
can you explain 'tappet-like' noise?
Offline gib6107
Re: Noisy 150 TDI
« Reply #3 on: 18 July 2007, 09:44 »
Rhyso - Oil is at about 1/2 full.
The_Ridge - not sure if diesels have tappets but it's the sound of the valves opening and closing I think, a sort of high-tone knocking.
Offline Ridg
Re: Noisy 150 TDI
« Reply #4 on: 18 July 2007, 09:57 »
that doesn't sound quite right.
when mines idling you get the distinct diesel noise but thats no louder than anyother and with the windows up you can't really hear it.
under acceleration the main noise i hear is the turbo forcing air in, similar to an induction kit noise.
do you get the noise if you rev the car stationary?  and is the noise constant?
Offline gib6107
Re: Noisy 150 TDI
« Reply #5 on: 18 July 2007, 10:15 »
The main noise is the turbo, the 'tappet' noise is only really noticeable when revved i.e. the more it's revved the loader it gets. Maybe just low oil..
Offline Ridg
Re: Noisy 150 TDI
« Reply #6 on: 18 July 2007, 10:24 »
lets hope its the oil, the only other thing that springs to mind could be one of the engine mounts or something.
Offline gib6107
Re: Noisy 150 TDI
« Reply #7 on: 18 July 2007, 12:45 »
jeez, don't scare me! Pretty sure it's not that serious. I'm taking it to VW in a couple of weeks so will find out more then. Need to ask a question about the oil though, if I just want to top it up, what is the best oil to get, and should I go to VW to get it?
cheers
Offline Ridg
Re: Noisy 150 TDI
« Reply #8 on: 18 July 2007, 13:11 »
EDIT: assuming your on fixed life service like me
i use Castrol Edge Turbo Diesel 5W-40 you can get in in halfords see link
link to halfords
its not cheap but its specifically designed for the PD engines.  you can use the halfords own brand stuff just make sure its got 505 01 approval
i'm not sure how much VW charge for their oil but would have thought it would be more than halfrods
EDIT: the edge and edge diesel are pretty much identical so its easy to grab the wrong one.
« Last Edit: 18 July 2007, 13:14 by The_Ridge »
Offline gib6107
Re: Noisy 150 TDI
« Reply #9 on: 18 July 2007, 13:35 »
think so, it's due a service in about 1500 miles. Was just going to top up beforehand.
