Author Topic: 1988 8v Engine Problem  (Read 2614 times)
Offline MadFox
« on: 19 February 2004, 13:48 »
I recently went to my car in the morning to go to work. I started the car, drove down the street and it stalled... Restarted drove further stalled. After about 10 stalls I got home and got it into my drive. The car now has an unusual idle status.
Basically i'm hearing a load knocking sound on the head, first impressions led to a bent valve. Also the revs are up and down, exhaust is making a pop pop pop sound and when the car revs it goes down and only just picks up from a stall.
Please advise on what I can do or where the problem may be.
Thanks.
MadFox
1988 Tornado Red 8v Gti
Offline Gambit
Re:1988 8v Engine Problem
« Reply #1 on: 19 February 2004, 14:05 »
sounds like the timing is out
i had this on my 16v when i changed the dizzy, forgot to mark the dizzy on the head, so when i first started it sounded exactly like what your describing
i just needed to rotate the dizzy a bit until i got it right
im not sure about the dizzy on 8v's
Offline richandhazel
« Reply #2 on: 19 February 2004, 14:10 »
Loud knocking from the head doesn't sound good. I think if it were me I'd want to know where that knocking is coming from. If you've dropped a valve you don't want to rotate the engine!!!!
Hopefully its not that serious.
Offline MadFox
« Reply #3 on: 21 February 2004, 15:57 »
I've driven it and the power is off a little.
The knocking is quite worrying. Not sure what I can do without having a tuner come check it out.
MadFox
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 21 February 2004, 16:36 »
a friend found a nut in his stump once. lol.
Offline bishthefish
« Reply #5 on: 22 February 2004, 00:13 »
did it do anything before the knocking or did it appear all of a sudden ?? ive had 2 timing belt tensioners go on me, and they both knocked, all though the bearings started squeaking loudly before they began banging  ! :o
« Last Edit: 22 February 2004, 00:13 by bishthefish »
bishthefish@btinternet.com  VARIOUS NEW AND USED MK3 BITS USUALLY AVAILBLE
Offline MadFox
« Reply #6 on: 22 February 2004, 13:58 »
Well 2 plugs aren't firing and the car is still driving... Thats 4v's down.
Gotta love the MK2 for its strength and durability.
I'm getting a compression test on monday, fitting new headgasket etc.
Fingers crossed I havent burnt the valves!!!
MadFox
turbo
« Reply #7 on: 24 February 2004, 02:41 »
i cant believe i havent had engine trouble with mine yet..... apart from cracked manifold.......i hope you get it sorted........nothing worse than being without your motor.....
Offline MadFox
« Reply #8 on: 25 February 2004, 13:41 »
Problem solved, maybe not what I hoped for but solved never the less.
Oil seals had been fecked, something along those lines. Anyway, the engine would need re-borring and many other things doing.
Just bought a new lump for ?300, and i'm gonna straight swap it.
Gotta swap my stage 3 cam across tho, and change the timing, few things but hopefully should be done before next week...
Me a happy golfer again.
Now where did I put that beesting aerial?
MadFox
