Author Topic: Brake causes stuttering... Why would it do that?  (Read 915 times)
Offline DRobbo
« on: 10 July 2007, 22:28 »
Right, after nearly 2 months off the road the Golf is nearly roadworthy again, and I can come back out from underneath it!!  :grin:
BUT... There is one last problem... Applying the brake causes the engine to stutter. I can find nothing wrong and all I have really done in the last couple of months is replace shocks and springs, rear brake pads, and bleed the system, and a bit of rust removal therapy.
Any thoughts?
Offline Thom89
  • Looking for an "Icebreaker"
Re: Brake causes stuttering... Why would it do that?
« Reply #1 on: 10 July 2007, 23:54 »
Sounds like you may have a servo vacume fault, check your brake fluid level is correct, and fluid is not being sucked into the engine!
Tom
Offline Mr Blue
« Reply #2 on: 11 July 2007, 01:25 »
sounds like a vacume leak yes
if not then just adjust the idle very slightly
Offline DRobbo
« Reply #3 on: 11 July 2007, 12:38 »
Hmmm... Brake fluid level is fine, problem occurs with any amount of revs so idle is fine...
So it sounds like a vaccuum fault! Any way of fixing/checking this? Or do I need to replace more parts??
So close!  :angry:
Offline Thom89
« Reply #4 on: 12 July 2007, 00:45 »
Its a problem that Ive not seen for many years, but I m thinking that the cure is a new servo... I could be wrong...
Tom
Offline nealey
« Reply #5 on: 14 July 2007, 22:36 »
Check the servo pipe or the gasket isnt split anywhere,
