Author Topic: Car cuts out at high speeds.  (Read 1112 times)
Offline logix42p
« on: 08 July 2007, 18:23 »
Right a couple problems with my golf have arisen over last week or so. Firstly when i was on the motorway and was doing around 70mph the car cut out on me a few times but then started again i can only assume this was because it was almost like a rolling start but at 70mph. So any ideas on what is causing this? it doesnt seem to do it at lower speeds etc.
Secondly there looks like a little oil coming out by the 3rd spark plug could this be related?
Cheers.
Offline Mew
Re: Car cuts out at high speeds.
« Reply #1 on: 08 July 2007, 18:34 »
Was it wet/raining on the motorway by any chance?
If so, change the leads and dizzy cap. My dad had that problem on his and they cured it.
Offline logix42p
« Reply #2 on: 08 July 2007, 19:26 »
It was totally dry and hadnt been raining for a day or two when it happened unfort. Also i changed the dizzy cap a few months ago.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 08 July 2007, 23:56 »
Could be fuel starvation, try replacing your fuel filter...
Tom
« Last Edit: 09 July 2007, 19:42 by thom89 »
Offline gibby
« Reply #4 on: 09 July 2007, 17:26 »
If you wiggle the key in the ignition does it sometimes turn off ? If so it could be a worn ignition barrel, as there's a white contact plug at the end that can wear out, or at least that's what I had on my mk1 cab when it cut out on me while driving.
......now officially dubless.
Offline hobbiniho
« Reply #5 on: 09 July 2007, 19:48 »
does ur car have an aftermarket immobaliser because this is the problem iv had with mine the immobaliser is not working properly so cuts the car off then it starts again, if u do have an aftermarket immobaliser and u dont know when and who fitted it i would remove it or get it replaced!! :laugh:
Offline mk2mark
« Reply #6 on: 11 July 2007, 08:50 »
Possibly the intank fuel primer pump too, mine's on the way out I think, similar problems.
