Author Topic: No fuel at Fuel Injector  (Read 1268 times)
Offline xrunner
« on: 08 July 2007, 16:39 »
Hello everyone,
I just purchased a 1990 golf GL *gasp* Yes I know it is not a GTI  :evil: I think you guys can still help me.  I was told that the engine was replaced with a 1.8L and that it had a 1.6L before.  I can not get it to start.  I have fuel all the way up to the throttle body, but nothing is spraying out of the injector.  I checked the carb fuse and it is good.  I just pulled the throttle body off and am going to try to find a used one unless you guys can give me any more possible solutions for my problem.  I am getting power at one of the pins on the harness for the fuel injector.
Thank You,
Matt
Here she is:
If you guys know anything about this engine, that would be great. I understand that there are many 1.8L with many different power ratings:
« Last Edit: 08 July 2007, 16:44 by xrunner »
Re: No fuel at Fuel Injector
« Reply #1 on: 09 July 2007, 13:15 »
dont quote me on this but that looks like an SPI lump, if so it will probably be a 90bhp unit out of a MK2 or MK3 Golf.  Does the fuel pump rpime when you turn the key?
Offline xrunner
« Reply #2 on: 09 July 2007, 15:29 »
Yes, it does prime fuel when I turn the key.
« Reply #3 on: 09 July 2007, 16:06 »
ok id replace the blue temp sender, a bad one can make the car not start, and also double check your timing :)
Offline xrunner
« Reply #4 on: 09 July 2007, 18:27 »
Is the blue temp sender located on the carb?  Would the timing being off not allow fuel to flow from the injector?  I would not think so, but need to make sure.
« Reply #5 on: 09 July 2007, 19:30 »
the blue sender is the one on the front of the head with the blue plug.
Offline xrunner
« Reply #6 on: 09 July 2007, 19:52 »
ok, so that must kill the engine if it gets to hot????  If it is bad than that could be my problem,  hmmm.  I will check that out.
« Reply #7 on: 09 July 2007, 21:52 »
no the blue sender tells the ECU how warm the engine is, if its broken it can send false readings to the ECU and prevent the car from starting cold :)
