Author Topic: MKV installation using Blaupunkt CanBus adapter  (Read 1551 times)
Offline p3eps
« on: 26 June 2007, 00:20 »
I've been preparing for this day for a long time!!!
Since I ordered my GTI about 15 weeks ago, I've had full intentions of fitting an Alpine iDA-X001 head unit into it - hence why I didnt order any audio upgrades from the factory.
I surfed around various forums and discovered that the MKV uses CanBus - so I asked around a bit, and bought a Blaupunkt CanBus adapter from Racetech for about £70.  The guy there told me this would sort all my wiring.
The stereo has been on back order for a while - and finally arrived on Friday... along with the Alpine KCE-300BT bluetooth adapter.
I've had quite a busy weekend, but have found the time to dissassemble my center armrest and run the USB cable into it - and take half the roof apart to fit my handsfree mic!
Today I decided to go for it and fit the rest!
I hacked the dash apart as described in several tutorials and everything seemed to be going well.  I removed the standard stereo and plugged in my CanBus... and then in my stereo.  It came on and seemed to work ok.  I then tried my BT adapter and it worked too.  I tied everything up nicely to prevent rattles and put the dash back together - and then went for a drive to test it.
All was well until it started to get dark...  I my auto lights came on, but my stereo did not dim.  I checked the settings, and it was set to dim.  My stereo had a loose orange wire which was for the dimmer function.  The CanBus also had an orange wire (but very poor instructions which didnt tell me anything) so I assumed the 2 oranges would go together - but perhaps not?
When I bought the CanBus I was assured by Ben that is would dim my stereo when the lights came on.  Thats why I splashed out £70 instead of buying a standard Autoleads £10 adapter.  Perhaps I've done something wrong?  Or perhaps this CanBus isnt meant to do what I want?
Has anyone had a similar experience that can help please?!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline Emeye
Re: MKV installation using Blaupunkt CanBus adapter
« Reply #1 on: 17 January 2009, 20:34 »
I notice that noone ever replied to this - did you ever get an answer?
Cheers. :)
