Author Topic: Becker Grand Prix 7993  (Read 1708 times)
Offline hockeylad72
« on: 25 June 2007, 08:50 »
Need some help, got the above head unit and the wiring to connect to an external amplifier, when I am on the phone via the inbuilt Bluetooth I can't hear anything, the person on the other end of the phone can hear me. I think that I have wired up the Amp incorrectly any ideas which wiring I should be using?
Here is a link for the picture of the wiring loom -
http://www.soundlabsgroup.com.au/mm5/merchant.mvc?Screen=PROD&Store_Code=Sound&Product_Code=Becker-5-Channel-Out&Category_Code=Becker
I am using a 4 channel amp, channels 1 & 2 are for the front and channels 3 & 4 are bridged for a subwoofer
any help would be appreciated
cheers
Davie
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: Becker Grand Prix 7993
« Reply #1 on: 25 June 2007, 11:24 »
I can't say for sure (because I don't have a Becker manual in front of me) but I'm fairly sure that the telephone audio (ie, what you would expect to hear when on a call) will not be output via the pre-outs - I think it may be the case that telephone audio is only output via the front high level (speaker) outputs, and that if you have your front speakers driven by an amplifier then you're not going to get telephone audio.
If you have music coming out of your speakers then your amplifiers are wired correctly - they either work or they don't. It's not possible to wire them incorrectly (with that loom) to give you music but not telephone audio.
Have a look through your manual. It may be that someone in the menu system there is a setting that allows bluetooth (telephone) audio to be played through the pre-out signal (and therefore through your amplified speakers).
On most car kits that are connected into the audio system (and not played through an external speaker) they work using the high level, unamplified outputs to the front speakers only, which are not it use in your car.
If this is all correct, and your are using non-amplified rear speakers, I can advise a way to re-jig your outputs to get this to work.
The greatest leveller of them all - the Carousel
