Author Topic: buzzing sound coming from speakers!!!!!  (Read 2716 times)
Offline adam20202
« on: 24 June 2007, 19:35 »
Hi folks, need help.
When i listen to cd's i get a buzzing sound coming from speakers that seems to be in time with the revs if you get what i mean. The higher the revs go the higher the buzzing sound gets. It is really strange but i dont know anything about sound systems and all that jazz so was hoping someone might have a clue to what is causing this and have the solution. Also the guy who had the car before me has a nokia hands free/phone charger fitted-could this be the probleem???
Any help would be appreciated
Offline mk2_singh
Re: buzzing sound coming from speakers!!!!!
« Reply #1 on: 24 June 2007, 19:39 »
poor earth connection. Upgrade the earth connection with thicker gauge cable to a secure point on the car. If you using bodywork then scrath away the paint and tighten the terminal to the paint free surface.
Offline adam20202
« Reply #2 on: 24 June 2007, 22:07 »
cheers for that, will try that. there was an earth cable i had to adjust before which was attached to gear box. i take it there is only one earth cable :undecided:
Offline nazzamataz
« Reply #3 on: 25 June 2007, 11:18 »
Im no expert on this area myself but,
If you've ran the power cable along the same line as the speaker cable, they maybe rubbing against each other and causing some weirdness, (Im slightly experiencing this in my car) in a perfect world the solution is to run power cable down the middle of the car and two speaker cable sets (assuming you have front and rear speakers hooked up to your amp) down either side of the car.
Hope this helps
Offline tommk3cab
« Reply #4 on: 25 June 2007, 13:00 »
na! i wouldnt bother with any of the actual main earths as i doubt it will be any of those, it might be though. especially if its been faulty before.
if your not getting any other problems, such as lights dimming or starting/charging problems then i would concentrate on the stereo earth itself first, if wiring it to the car body sorts it, then the gearbox earth is definately not causing you any problems.
the one to look at is the black wire coming out of the back of the stereo loom, it will probably need cutting and replacing with a wire attached securely, direct to clean metal car body, so the handbreak or other bolt/screw in the passenger compartment would be a good place to start.
however, if the gearbox earth is faulty then replacing the one from the stereo will not solve much because all you will be doing is making a good stereo earth wired up to a poor connection to the battery ( through the car body)
are you running an amp? if so the ones to really watch are RCA cables next to power cables as they can interfere with each other because of the small currents carried by RCA's but i ive never noticed it when they are running together, although I run them seperate because its just something ive heared too, bit of an urban myth I (and many others!) reckon. This also definately wont effect any speakers running off the HU so its easy to find out if this is causing you problems ( which i very much doubt it is!)
ground loops are quiet common though, get a ground loop isolater from halfrauds to solve that problem.
if its an alternator whine, may need an alternator surpressor for that, again im pretty sure halfords sell them. the stereo earth will be the way to go first though.
Offline adam20202
« Reply #5 on: 05 July 2007, 19:08 »
Well thanks for all the help and i will try a few of these things out.
I dont actually have an amp fitted-everything is standard apart from the owner before me had fitted a hands free/charger to the stereo. I thought maybe this was causing some problems. I will check the earths tho.
Thanks for all the help :wink:
Offline tommk3cab
« Reply #6 on: 06 July 2007, 22:11 »
having no amp will make it much easier, its pretty much got to be the black HU wire. the hands free kit may not have been done properly you could be left with problems now because of it, but the problems will go away if you redo the black wire, its almost 100% chance thats the problem wire.
Offline adam20202
« Reply #7 on: 08 July 2007, 22:44 »
Ok, will defo check this when i have a spare minute.
Offline Simpson
  • one day il learn
« Reply #8 on: 17 July 2007, 13:10 »
another thing to possibly check if all that doesnt work, is a screw through a wire, or break, i had that problem and i had gone through a wire with a dash screw.  :smiley:
i must buy a new car!
Offline Golf_Spunce
« Reply #9 on: 19 July 2007, 10:19 »
bad earthing....fix to an actual earthing point such as by the lights or something, much better than making your own (scratching paint)
