Author Topic: any ideas??  (Read 898 times)
Offline Smegsterman
any ideas??
« on: 24 June 2007, 13:52 »
hey guys,
been having the standard problem of idling badly and running like a bag of spanners low end.
this is what ive done thus far:
super 4 plug change
splitfire leads
dizzy cap and arm
k and n 57i
ecu chip
checked all electrical wiring and hoses....all peachy except one for oil temp on mfa which spade has broken off.
cleaned up connections and sprayed carb cleaner everywhere.
i kindda made a boo boo trying to adjust idle and altered wrong one (small screw with nut) tryed to correct that anyway.
now she is still hunting but not as bad and no longer dies at junctions but still a little lumpy low end untill picks up.
the exhaust is blowing slightly and was wondering if thats part of problem (gonna change is to mongoose very soon) or does the car need a tune up.. with co and mixture etc. i did notice the mixture seemed to be to strong when i took out old plugs.
on a separate note...the plastic cover thing next to fan belt has broken on the screw bit so is rubbing on belt now, any easy way to solve that.
cheers in advance
Offline Mr Blue
Re: any ideas??
« Reply #1 on: 24 June 2007, 14:42 »
I had this
'Rubjonny' sugested i look at the throttle switch wires. yep they were broken which caused the same problem
check for air leaks in the small vacum hoses
worth changing the blue temp sensor too
I took the cam belt cover off as mine had a crack which started to rub on the belt. Not reccomended but im better off  :laugh:
 :smiley:
« Last Edit: 24 June 2007, 14:44 by Mr Blue »
Offline Smegsterman
Re: any ideas??
« Reply #2 on: 24 June 2007, 14:45 »
i forgot to put i changed the blue temp sensor, the wiring by the throttle seems ok to me.......
btw on the connector that goes to the ecu one of the red wires is going nowhere and just sat there and i was wondering what its for?
its the connector on top part of ecu not scart looking one
Offline cняis
Re: any ideas??
« Reply #3 on: 24 June 2007, 15:05 »
check the rubber "grommet" which holds the "flying saucer" onto the rocker cover... mine split causing erratic idle, popping through over-run and stalling at junctions.
Offline 8vRicey
  • Silver Mettalic 8v GTI
Re: any ideas??
« Reply #4 on: 24 June 2007, 17:05 »
idle stabalisation valve ??  :smiley:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
Offline Mr Blue
Re: any ideas??
« Reply #5 on: 24 June 2007, 17:32 »
tbh ive never seen an isv fail  :huh:
thats only to keep the engine idle so i doubt its that anyway. am i right?
Offline Smegsterman
Re: any ideas??
« Reply #6 on: 24 June 2007, 20:39 »
ive changed the isv anyhow just in case
