Author Topic: Wheel rubbing - HELP!  (Read 1661 times)
Offline Classic16v
« on: 23 June 2007, 17:49 »
I've recently put some 15x6.5 G60 BBS wheels (ET33 i believe...) on my standard 16v and with passengers in the back the sidewalls rub on the inside of the arches.  I was told 6.5Js should fit the mk2?!  It's not lowered (although I think the springs may be a bit soft) - surely I shouldn't need to roll the arches for this?! I know the original RAs are 6J but should that extra 0.5 make that much difference?
Offline kittie
Re: Wheel rubbing - HELP!
« Reply #1 on: 24 June 2007, 16:41 »
It depends on the offset as well as the width of the wheel.
I had 6.5Js on my mk 2 and they were fine
However, now I have 7Js with an offset of 24 and they rub to buggery  :smiley:
Offline rowlers
  • I'm back - MK7 GTI
« Reply #2 on: 24 June 2007, 16:58 »
that size wheel with that offset I don't beleive should rub at all!
I have 15*7 ET28, no rubbing on front, but slight rubbing when larging it over sweeping bumpy roads
Offline Classic16v
« Reply #3 on: 24 June 2007, 19:26 »
Do you know if that rubbing you get is on the inside edge of the tyre or the outside?  I realised my thread may not have been too clear about where mine rub - its the outside edge of my tyre which rubs.
Offline rowlers
« Reply #4 on: 24 June 2007, 20:18 »
mine rub on the outside
Offline kittie
« Reply #5 on: 26 June 2007, 10:02 »
ET 24 to 28 must make quite a difference - mine rub a lot front and back (certantly couldnt have anyone sit in the back at all), am really surprised!
Personally I'm thinking of getting about 5mm machined off them. I like them and I will make them fit!!  :grin:
Offline rowlers
« Reply #6 on: 26 June 2007, 19:38 »
it has had the arches tweaked tho!
et33 shouldn't rub at all
Offline takethefifth
« Reply #7 on: 26 June 2007, 21:55 »
Try taking a wheel off and finding an offset stamp on a wheel to double check and are you 100% that the springs aren't lowered?
Really wouldn't have thought those would have rubbed with the setup you've described. I ran 17" 6.5's with a 40mm drop and only very minor rubbing over big bumps.
Offline kittie
« Reply #8 on: 27 June 2007, 10:13 »
Aha now it becomes clear, my arches are virginal and untouched  :smiley:
Offline Simpson
  • one day il learn
« Reply #9 on: 27 June 2007, 22:53 »
I know why they rub, they probably have 205 with tyres on them as used on the Corrado,, therefore you have a slightly lower offset than standard i.e et 38 or 35 and an extra width of tyre, if you fit 195 50 15s on those rims i doubt there will be any scrubbing as you are only going a coulple of mil lower than ras.
i must buy a new car!
