Author Topic: solid mount att joe  (Read 1366 times)
Offline gteyes
solid mount att joe
« on: 23 June 2007, 12:16 »
fitted the solid mount in last week that joe form the forum sold me thanks joe, to me has made a huge differance no more engine rocking when putting the foot flat down
As for the viberations hardly have none just a small bit in the sunroof but will get around to shorting it out someday
and on start up it gives a bit of bigger kick but nothing to bad :laugh: :smiley: :grin:
Offline Mr Blue
Re: solid mount att joe
« Reply #1 on: 23 June 2007, 19:12 »
i forgot to ask Joe at the show
Joe u still got one? bring it to the next show if you have :smiley:
Offline rowlers
  • I'm back - MK7 GTI
« Reply #2 on: 23 June 2007, 19:12 »
how long did it take to fit?
how to?????
I've got mine sitting waiting to go on, so glad it works!
Offline gteyes
« Reply #3 on: 23 June 2007, 19:23 »
fitting front solid mount
it took me less than 20 min to all you need to do is
 place a jack under the gearbox with a bit of wood between the box and jack  raise the jack up untill it just makes contact with the box lossen the top nut untill off then go under the car remove the bolts 13mm and 16mm jack the box up so the mount can move slide the mount out i took it out the side of the oil filter found there to be more room this side
fit new mount in may require longer bolts for the 16mm under the car lower the box a small bit put all bolts then lower all the way tighten up bolts i used some lock thread on them and job done  :laugh:
Offline bomp
« Reply #4 on: 23 June 2007, 19:24 »
@ Rowlers. Get a jack under the sump with a wide peice of wood between them, jack it up until you see the engine move up a bit then undo the 3 bolts and swap the old for new. About 10-20 minutes work.
Ahh, ooops, your versions better gteyes  :grin:
« Last Edit: 23 June 2007, 19:26 by bomp »
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Ben Lessani
« Reply #5 on: 27 June 2007, 00:29 »
How much do these mounts cost, I seriously need one otherwise I'll keep knocking the exhaust off.
Offline ...joe
« Reply #6 on: 27 June 2007, 20:58 »
cool, glad your happy with it! blue i sold 'em all but might be able to get some more. not sure when i'll see you next though!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline CMD
« Reply #7 on: 27 June 2007, 22:17 »
Joe i'm in need of one (mk2 8v)..how quick can you get hold of them..
« Reply #8 on: 29 June 2007, 10:46 »
Joe I can't believe you want to go through all that again :grin:
If peeps want em sharpish check out BBM motorsports online shop, they'll ship to the UK and the $ exchange rate is quitre good at the moment :)
