g60 head is heat treated and has sodium valves... pb head wont do the trick.
G60 has slightly bigger zaust ports I think as well, whereabouts do you live?
Plus the cam in a PB head is all wrong, though you can just fit your old G60 one if its not damaged. What have you done to the old head then?
Quote from: topher on 20 June 2007, 22:10g60 head is heat treated and has sodium valves... pb head wont do the trick. what would happen then if i did use one?
