Author Topic: MKIV Speaker problem  (Read 2288 times)
Offline Rhyso
« on: 18 June 2007, 14:22 »
got a Gamma headunit and 8 speakers in my MKIV; every now and again my main front speaker on driver's side doesn't work.  some days sound comes out and others it don't  :undecided: i've had a fiddle around with the connections at the back of the head unit but to no avail  :sad:
I've taken the door card off and looked at the connections and all seems ok  :undecided:
i've got a feeling the speaker may be on its way out but was wondering if anyone has any other ideas  :undecided:
Cheers  :smiley:
Offline AlanD
  • MK5 2.0T 16v
Re: MKIV Speaker problem
« Reply #1 on: 18 June 2007, 15:04 »
Mine did this once and I spent ages trying to work out what was going on and did all the things you said. I then checked the settings and somehow I had managed to change the settings so all the sound was coming out the rear rather than the front.
This probs wont help you as yours is ok one day and not the next.
Offline Rhyso
« Reply #2 on: 18 June 2007, 15:20 »
yeah thats how i found out it wasn't working.  i thought i was going deaf in my right year at one point!  :laugh: :laugh:
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #3 on: 18 June 2007, 15:31 »
Before you rush off to buy replacement speakers, have you checked the integrity of the actual wire?
The connections at the reear of the head unit and to the speakers themselves may be mustard, but have you checked the state of the wores carrying the signal?
An intermittent fault possibly suggests a broken/shorting wire - check the wires within the rubber sleeve between the A pillar at inner door edge (where the wires leave the car and enter the door. It;s not unheard of that the wires in here become damaged, resulting in a intermittently broken signal.
The greatest leveller of them all - the Carousel
Offline Rhyso
« Reply #4 on: 18 June 2007, 18:10 »
cheers mate :afro: that will be my next point of investigation.  as you say, the fact its intermittant suggests a break in the connection somewhere. can't afford new speakers anyway so lets hope its something as simple as a break in the wire lol
Offline mattp1983
  • Keep it VAG :)
« Reply #5 on: 20 June 2007, 21:33 »
if its any consolation the speakers are about £18 a peice from VW so not going to break the bank if it screwed, my guess its around the door gromit area, sometimes wires can snag and then get pulled and frayed when the doors are opened and closed. Pug 306s were renowned for this (all the 3dr wiring into the doors was about 2-3mm too short in the factory and they wore thin with age and split, lol)
1989 Golf GTI 8v Tornado Red <br />2004 Bora Highline TDI 180bhp Shadow Blue
Offline Biteuk
« Reply #6 on: 09 July 2007, 19:53 »
i know it's stupid again, but on my old corsaasand papered down the connecters themselves, and hey presto.
