Author Topic: gttdi more POWER!  (Read 6031 times)
Offline Gt-tdi
gttdi more POWER!
« on: 14 February 2004, 16:09 »
hello peeps, ive got a GT TDI 115bhp and was just wandering whether i could easily reprogramme the engine chip to produce 130/150 bhp? is that the only difference between faster diesels? And if that the case, how much approx? CHEERS!
TDI = economy and FAST!!
Offline Ianhg
Re:gttdi more POWER!
« Reply #1 on: 14 February 2004, 20:26 »
so its more power that your after?
good lad
anyway.the 115tdi is abit different to the 130 and 150 tdi.
the clutch is weaker and can cause trouble when you chip it.
you can chip a 115 to give you more power,my 130 is chipped to over 170bhp and 300lbs of torque.so its possible.
Golf Mkiv Gt TDi 130pd
AMD One Click,R&R=171bhp 300lbs,Santa Monicas,De-Locked,W8 Mod,Cruise,6CD,Lowered,GT TDi rear+TDi grill badge/
Offline nrgizerbunny
« Reply #2 on: 14 February 2004, 21:12 »
i don't think the 115bhp version is a PD (need someone to help me out here)
in which case you can't get one of those boxes to plug in and give you more power. the only viable option is to go for a rechip and even then I don't think you would get 130bhp.
i think the clutch would be okay at 130bhp, might need to think about it at 150bhp (i personally thought allt he clutches ont eh diesels were the same but obviously not). its the driveshafts i would worry about.
sanj
Offline R32_T
« Reply #3 on: 14 February 2004, 23:04 »
Hello mate, you wanna try changing the Injectors, try and get some injectors of a 150 bhp model. It might make a difference and obviously the more bhp the bigger the injectors. Cheap and cheerfull!!  :)
« Last Edit: 14 February 2004, 23:06 by R32_T »
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
Offline antgti
  • 130PD Gti with Van aaken chip to 165 has now gone,
« Reply #4 on: 15 February 2004, 04:24 »
injectors, Cheap!
only the medical ones i'm afraid, changing the injectors on your 115 will do absoloutley jack sh!t, in fact you may as well take your spare wheel out as that will see more gains than changing the injectors.
See its all about the controlling of the injectors, so this means you need a tuning box or chip, i would personally go for the box as i have one and you can also take it off if necessary.
If you are looking o get sh!t tones of power out of your car then, ring autotrader and say can you list my car, then sell it and then buy a bigger diesel, eg 130 or 150 if you can push it, or even a ptrol turbo.  there is never any point in throwing thousands at a car when it can be acheived by just buyig a new one.
THe difference between the PD engines is'nt just the ECU.the 150 has a bigger turbo, a strengthened crank.  The 130 is different to the 115 but not sure the exact spec change, but speakk to a through people at the companies like AMD, Van-aaken and Jabba sport etc etc.  Read the links on here and then make yuor decsion,  But if you ask me, with the influx of mobile speed cameras in my area , i am thinking of getting a Sinclair C5 as it is a sheer miracle that i have not been done for speeding yet, i might downgrade my car to the SDi normaly aspirated diesel to aoid fines.
Me old diesel was quick/........
16.004 sec Qtr mile @ 85mph 23/5/04 Santa Pod
Now running around in soon to be REVO'd Seat ibiza 1.8T 20v FR and missing the fuel economy..............
Offline frosticles
« Reply #5 on: 15 February 2004, 21:02 »
Have a word with Simon Coe from Upsolute. You won't be disappointed
1978 Ford Escort MK2 RS Mexico, GTiTDiPD150. RS2's,Cruise,Metallic Black, Upsolute re-map. Goes and smells like stink.
Offline Terminator
« Reply #6 on: 16 February 2004, 10:37 »
Do not under estimate the issue of clutch slip which is a real problem with many of the chipped MKIV's. With the weaker clutch on your model you may also want to consider a tuning box from a company like Van Aaken or Oettinger. These are very good quality and German TUV approved which means that the resulting torque figure should be within the tolerances of your clutch. With a diesel don't worry about bhp as its the torque figure that is the real measure of performance.
« Last Edit: 16 February 2004, 10:40 by Terminator »
GTi PD150, Revo'd, Hasta La Vista!
Offline antgti
« Reply #7 on: 16 February 2004, 11:44 »
before anyone starts the above comment is to be stricken from the record, we are not gonna start off about BHp vs Torque.
PS see post on Van-aaken box, c'est tres bien
Offline Terminator
« Reply #8 on: 16 February 2004, 16:08 »
We are talking diesel here so I stand by my comment about torque.
Offline S11EPS
  • No golfs here. Only a C63 mercedes
« Reply #9 on: 16 February 2004, 16:13 »
^^^ and I stand beside him  ;D
The greatest leveller of them all - the Carousel
