Author Topic: soft top  (Read 1601 times)
Offline carpetmonster
  • carpetmonster 16v keep it retro
soft top
« on: 16 June 2007, 18:01 »
Afternoon i have just bought a convertable golf and there does not seem to be any power going to the hud.Does anyone know where there is a fuse or relay.cheers.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: soft top
« Reply #1 on: 16 June 2007, 18:46 »
ooh, another cabby locally ey  :wink:
ill have to pop along and see your ocollection sometime dude  :grin:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Mr Blue
Re: soft top
« Reply #2 on: 17 June 2007, 20:10 »
What model?
MK1 or MK3?
If its a mk3 then they work with hydrolic fluid.
Dont know anything about mk1's sorry :embarassed:
usual checks...
Fuses, Switch, Trace wires back (possibly broken wire), hydrolic fluid level (mk3)
Re: soft top
« Reply #3 on: 17 June 2007, 20:23 »
yep it's a mk3 level is fine,but a test lead into the red wire and have nothing.
Offline Mr Blue
Re: soft top
« Reply #4 on: 17 June 2007, 21:32 »
Dont know the fuse number but pull them all out one by one.
If they are fine then test the switch or bridge the wires on the connector block and see if something moves :wink:
mk3 switches are pants
Offline herbster
Re: soft top
« Reply #5 on: 20 June 2007, 23:15 »
Borrowed my boses wife's one a couple of years ago, to operate the roof the engine had to be not running with the ignition on, so could well be a relay!
Good luck  :smiley:
FAB is my life and the CABRIO's the wifes!!!!
Offline RandomJord
Re: soft top
« Reply #6 on: 21 June 2007, 11:08 »
f**k it, use it manual, thats what i do!
Skoda Octavia VRS DSG (soon!)
Skoda Rapid Spaceback
An a Signum for towing me old caravan!
Offline robiwill
Re: soft top
« Reply #7 on: 21 June 2007, 11:34 »
we had one with a hood problem found it was the ignition switch ha worn, we got it too respond by pushing the key up on ignition on and it sorta worked judered replaced the ignition switch and it was perfect just a thought
Re: soft top
« Reply #8 on: 21 June 2007, 19:39 »
robiwell you are correct,i tryed that and blow and behold it worked.cheers boss :rolleyes:
