Author Topic: Power Rhor - What is it?  (Read 4194 times)
Offline m4nesh
« on: 13 February 2004, 20:56 »
Sounds dopey ??? but anyone know what one of these power rhors is? Seen them advertised on websites and on a post earlier post.
cheers
Offline lewis
Re:Power Rhor - What is it?
« Reply #1 on: 13 February 2004, 21:34 »
It's a piece of pipe coming from the metering unit to the throttle body. It's made of metal instead of plastic, I'm not too sure if there is any real power gain or if it?s for sound/looks.
Offline jedi16v
« Reply #2 on: 13 February 2004, 23:30 »
possibly good for a bit extra power if you add a decent airfilter /induction kit . i got one fitted . made a difference with noise when i drilled my air box . right grunty muddy funkster i can tell you . looks pretty aswell . nice stainless steel mine is . if you want one would recomend www.trimsport.co.uk . very helpful people and everything is hand made. :)
Offline rustynuts
  • God is a DJ
« Reply #3 on: 13 February 2004, 23:50 »
Got one on the Mk1, pipe is wider and more direct than original. Also I have got a Digifant spec throttle body on mine so hopefully i am getting better airflow to the engine. My car sounds like a demented wasp in a Jar when it opens up. ;D
turbo
« Reply #4 on: 14 February 2004, 01:24 »
how does this connect the throttle and the air flow meter does it come with rubber connector bits......
i ve seen 1 in the mags he had his connected by some sort of blue rubber with jubelee clips....
and i userstand the pipe from the isv goes into as on the factory one!!
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 14 February 2004, 01:30 »
A picture tells a 1000 words ;D
There were no noticable power gains for me. it just looks nicer :)
Offline rustynuts
  • God is a DJ
« Reply #6 on: 14 February 2004, 18:00 »
So your car was silver originally was it?  ;)
Blue MK2
« Reply #7 on: 14 February 2004, 18:19 »
tidy engine dizzy  :D :D
Offline Dizzie
« Reply #8 on: 14 February 2004, 18:29 »
no my car was white originally. and the engine is for sale ;D
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
« Reply #9 on: 14 February 2004, 18:47 »
did i see a can of red bull under your bonnet???  Or is it jus me?  You have a water deflector under there or is that the original plastic bit?  Just I've got one in the post and was wondering where to fit it, whether to remove the old plastic thing and whether they were any good?
« Last Edit: 14 February 2004, 18:50 by marcogolfo »
