Author Topic: Power Rhor - What is it?  (Read 4193 times)
Offline Dizzie
  • Make friends with your fast
Re:Power Rhor - What is it?
« Reply #10 on: 14 February 2004, 18:57 »
the redbull can is my coil
the plastic near the window channels water to the sides and out.
Offline e-lustrious
« Reply #11 on: 15 February 2004, 00:11 »
If you get the march edition of  The Golf mag and go to page 76, it shows you all you need to know and how to fit it etc...... ;)
Offline Dizzie
« Reply #12 on: 15 February 2004, 06:04 »
fitting is piss easy.
just undo the 2 jubiley clips, remove 'orrid plastic pipe, poke in the new shiney one and do them back up.
Offline jedi16v
« Reply #13 on: 15 February 2004, 14:05 »
they are easy to fit but can be a bit tight to fit the rubber pipes on to. what i done was take the pipes of and heated them with a hair dryer made plastic more elastic and  easier to fit. :)
Offline Dizzie
« Reply #14 on: 15 February 2004, 16:48 »
I just rammed mine in there ;D
Offline AdamB
  • The Perfect Storm
« Reply #15 on: 15 February 2004, 21:00 »
LOL - you really are the ladies man   ;)
I don't own this anymore - I just can't be arsed to change the picture
Offline Dizzie
« Reply #16 on: 16 February 2004, 11:31 »
thanks Ad  :-*
Offline Gambit
« Reply #17 on: 17 February 2004, 11:19 »
them power rohr's are technically worse for the air flow as they are not mandrel bent, the bend is just welded - so the airflow is disturbed when it hits the bend
there is an american company that does a mandrel bent version for ?70, but i cant remember their name
its something like, AMD, SMD, or AMB or something!!
Offline Dizzie
« Reply #18 on: 17 February 2004, 16:08 »
or even ABD Racing (tel - 01634 710777 / fax - 01634 252871)
www.impossible-performance.cwc.net
« Last Edit: 17 February 2004, 16:09 by Dizzie »
Offline Gambit
« Reply #19 on: 17 February 2004, 16:53 »
aye thats the one!
