Author Topic: Clock needles................removal and re-fitting  (Read 894 times)
Offline moonsta
 :smiley: as some of you will know i run a south african jetta everyday and wish to change the clocks for mph ones instead of kph.i have a set of '89 gti 8 valve clocks,so would i be best just changing the lot and would they read right (suspect that the jetta has 4+e box in it) or fiddle about taking the lot to bits?? advice and opionions appreciated..............just to make you all jelous yes the jetta has air-con and yes it works!! cheers gang :wink:
Drives '96 Polo 6N and '85 Mk Golf Gti...
Offline Mr Blue
Re: Clock needles................removal and re-fitting
« Reply #1 on: 14 June 2007, 21:58 »
Once you pull the needles off you cant get them to read accurately again. :embarassed:
Just change the lot. You can just change the speedo section and leave the original rev counter section in place
Offline bomp
« Reply #2 on: 15 June 2007, 02:22 »
If you look at this page, http://www.4130-products.com/step/install/index.htm and just read the parts for removing and replacing the needles, you should be fine.
I had a set of clocks that I wanted to mess about with, but the needle didn't come to rest just after the the needle stop, it wanted to go beyond the clock/mile counter, so I got another set instead.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
« Reply #3 on: 18 June 2007, 10:53 »
the trick to removing & replacing the speedo needle is as it says in that guide, before you pop the needle off lift it over the stop and make a note of where it stops, then make sure you put it back on the same way!
If you just swap the clocks over they should read correctly, but if not you just have to swap the speedo gear on the gearbox end.  Carefully lift it out (the gear likes to fall off the end into the box which isnt good!) and swap it over.  There are 2 types for petrol engined cars, you have a white & a red one.  Simply swap it over to the other colour :)
