Author Topic: Front suspension  (Read 1805 times)
Offline rzacasperof
Front suspension
« on: 14 June 2007, 17:12 »
Hi there, It appears that my front damper needs replacing, problem is the strut appears to be a sealed unit so I can't simply replace the insert??  The only place I've been able to find that sells the strut complete with damper is the VW dealer but there £80!!!  Does anyone know where I can get one a bit cheaper than that?  Can I get a strut which is not sealed off a Mk2, replace the damper and fit that??
Offline richandhazel
Re: Front suspension
« Reply #1 on: 16 June 2007, 22:46 »
The original strut all forms part of the shock absorber.
When you buy the replacement, it is an insert that fits within the original strut.
