Golf mk2
clutch cable
Topic: clutch cable (Read 2681 times)
jasonpi
clutch cable
13 February 2004, 15:34 »
how hard is it to adjust the clutch cable ona a mk28v engine?
golfvr6
Guest
Re:clutch cable
13 February 2004, 15:39 »
easy , unless you have a self adjusting type.
there will be an adjustment nut gearbox end if it is adjustable.
jasonpi
Re:clutch cable
13 February 2004, 15:49 »
ok heres a pic of it
golfvr6
Guest
Re:clutch cable
13 February 2004, 15:56 »
That is the self adjusting type, the boot houses the spring that keep the cable under tension. You should have a white strap round it so you can compress it to remove the cable. If you need to change the cable then use the strap off the new cable.
Last Edit: 13 February 2004, 15:57 by golfvr6
jv
Administrator
Serious forum addict
Re:clutch cable
13 February 2004, 16:02 »
mechanic bloke swapped my auto one for a manual adjustment cable as he reckoned they are much better - just left him to it!
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
jasonpi
Re:clutch cable
13 February 2004, 16:04 »
cheers looks like new clutch is needed :'(
golfvr6
Guest
Re:clutch cable
Reply #6 on:
13 February 2004, 16:05 »
New cable won't cost alot, fairly easy to fit.
jasonpi
Re:clutch cable
Reply #7 on:
13 February 2004, 16:07 »
no reason i was asking was not to replace the cable but to see if it was manual adjustment so i could get a bit more bite out of it knowing that its automatic must mean the clutch is at the end of its life as it is starting to slip
modulater
Re:clutch cable
Reply #8 on:
13 February 2004, 20:03 »
where on the pedal does the clutch bite?
jasonpi
Re:clutch cable
Reply #9 on:
13 February 2004, 21:31 »
il get back to u on that 1
Golf mk2
clutch cable
