Author Topic: sub in an r32  (Read 2377 times)
Offline middleweight
sub in an r32
« on: 11 June 2007, 01:43 »
how would i put a sub into my r32?
with the  standard car sterio. thanks
Offline tommk3cab
Re: sub in an r32
« Reply #1 on: 11 June 2007, 19:30 »
hmmm, depends, do you know if the stereo has RCA ( red and white ) jack outputs on? i doubt it but without them you will have some problems.
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: sub in an r32
« Reply #2 on: 12 June 2007, 12:24 »
Is this a MKIV R32?
To be honest, it's no harder installing to a factory head unit than it is to an aftermarket one - you just need an extra bit of kit:
http://www.lowcostcaraudio.co.uk/shop/Autoleads-PC3-11-PC311-Yellow-Mini-ISO-to-RCA-Leads_searchTextJJAutoleadsZZsearchMethodJJproductManufacturerZZpageJJ23ZZproductJJ1747
That plugs into your factory fit head unit and gives you a front and rear pre-out, as well as a remote wire.
In addition to this adapter you will also require:
Power cable (to run from battery to amplifier location) suitable for power of amplifier
Fuse holder and fuse - You MUST site this within 12 inches of battery (definitely engine-side of bulk head) for safety reasons
Earth cable (to run from amplifier to suitable earth point) Must be of suitable guage.
Remote wire (to run from new adapter on the back of the head unit to amplifier location - turns amplifier on when head unit comes on)
RCA cables (to run from new adapter on the back of the head unit to amplifier location - carries signal)
1 x amplifier
1 x subwoofer + enclosure
Couple of hours to install it all.
Any probs, give us a shout.
People often don't realise how cheap it is to get this stuff installed for them professionally. Most car stereo shops will install that (not including parts) for less than a bullseye, which if you're a novice at installing and lack the confidence to do it, has got to be money well spent.
The greatest leveller of them all - the Carousel
Offline tommk3cab
Re: sub in an r32
« Reply #3 on: 12 June 2007, 15:39 »
didnt realise they were that cheap and I think I've heared a system run off one before and wasnt too impressed. is this one of the things that make you lose your standard speakers. these are the problems I speak of! if that doesnt bother you or this dongle thing somehow gets round that, then problem solved!
« Last Edit: 12 June 2007, 15:42 by tommk3cab »
Offline S11EPS
Re: sub in an r32
« Reply #4 on: 12 June 2007, 15:41 »
Nope, speaker outputs remain working.
Offline tommk3cab
Re: sub in an r32
« Reply #5 on: 12 June 2007, 15:43 »
ah your on, quality! how does that work then? the only ones ive seen before ' steal ' the speaker wires?! does it not plug into the HU where the spk wires come out?
Offline S11EPS
Re: sub in an r32
« Reply #6 on: 12 June 2007, 16:26 »
No, it isn't a line-to-RCA converter (they are the ones you;re thinking of, which connect onto the speaker outputs), this is an additional module which plugs into a spare slot in the back of the headunit.
What you will find a lot of manufacturers do when they produce their 'own' stereo's is they partner with a manufacturer to have something built for them, or they licence the rights to badge engineer a previous generation of a given manufacturers stereo.
However, to save production costs, they delete the sort of stuff which is plentiful on aftermarket equipment, such as RCA connectors etc. as they are not needed in a 'standard' configuration.
However, it's more expensive to delete these things at circuit-board level (requiring bespoke boards and components etc) so they are produced with the capability of full functionality, but they forego fitting the requisite connectors to save the vital pennies.
Hence, you can buy these plug in modules - the stereo was always capable of doing the job of RCA pre-outs, remote-on switching etc it just lacked the connectivity to do it, because the stereo is produced to meet a certain price point.
Offline tommk3cab
Re: sub in an r32
« Reply #7 on: 13 June 2007, 16:35 »
yeah thats what i was thinking of, never seen another solution, cheers s11eps, every day is a school day!
