Author Topic: earth point  (Read 1642 times)
Offline ian007miles
earth point
« on: 10 June 2007, 21:19 »
hi peeps can any 1 tell me were the the best place to earth my amp in my mk1 golf, near the back seats cos my amp is on the back of the seat thanx ian
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline tommk3cab
Re: earth point
« Reply #1 on: 11 June 2007, 19:38 »
where the seatbelts join the chassis under the back seat, or the side seatbelt chassis joint by the back doors. you will need a big spanner or ratchet though ( 17mm normally ) and they are normally very tight.
make sure you clean the bolt up a bit too where the earth wire will connect and screw the bolt in then unscrew it a few times to clean out the thread of the hole the bolt goes in.
