Author Topic: sub box wadding  (Read 2776 times)
Offline eddie1905
sub box wadding
« on: 07 June 2007, 19:07 »
Hi ive got a ported sub box do you think it would be worth me filling it with wadding ive heard its good for sealed boxes but wasnt sure about a ported box . thanks
Offline Len
Re: sub box wadding
« Reply #1 on: 07 June 2007, 20:18 »
Wadding is always good in the tight corners. Plus at the back to deaden the bounce off hard surface.
www.sas.org.uk
www.the-ace.org.uk
Offline Heyho
Re: sub box wadding
« Reply #2 on: 07 June 2007, 21:41 »
Wadding can be useful if you have a sealed box - it gives the effect of a larger enclosure, but you only want to do this if your enclosure is too small (in volume) for the driver.
Wadding should be kept to a minimum in a ported box, to keep the path clear between driver and port.
Offline tommk3cab
Re: sub box wadding
« Reply #3 on: 07 June 2007, 23:14 »
just dont stuff it too tight and you will be fine, rip apart some old teddy bears if you come across any, its the same stuff (ing!). or they sell it on ebay for cheap.
Offline Ben Lessani
Re: sub box wadding
« Reply #4 on: 01 July 2007, 09:18 »
dont bother doing it on a ported box. it is designed with a proper port width/length in mind given the enclosure size and air volume. putting any material in the box would just have an adverse effect...it doesnt really make that great a difference with sealed boxes.
Offline Len
Re: sub box wadding
« Reply #5 on: 02 July 2007, 14:21 »
Home HiFi speakers have ported designs, they always have wadding inside them.
Sound does not like hitting hard angles. whereas speaker boxes have right angles and corners!
So yes it is worth using wadding.
www.sas.org.uk
www.the-ace.org.uk
Offline Ben Lessani
Re: sub box wadding
« Reply #6 on: 02 July 2007, 21:18 »
"...it is designed with a proper port width/length in mind given the enclosure size and air volume..."
"Home HiFi speakers have ported designs, they always have wadding inside them."
Thats because they are designed as such. If the manufacturer designed the box needing additional padding, they would have done so.
Go to talkaudio mate and they'll all give you a good concise answer.
Offline Len
Re: sub box wadding
« Reply #7 on: 02 July 2007, 21:35 »
If you have studied and built HiFi speakers like I have maybe you wouldnt believe everything you read!
basic sound dynamics - sound bounces off hard surfaces! Think about echoes!
www.sas.org.uk
www.the-ace.org.uk
Offline eddie1905
Re: sub box wadding
« Reply #8 on: 04 July 2007, 18:00 »
Ok cool cheers for the comments think I'll give it go and if does'nt sound right I can just remove it.
