Author Topic: Drinks Water  (Read 2092 times)
Offline WhiteMk2Gti
Drinks Water
« on: 06 June 2007, 12:53 »
As in expansion tank every other day.
Oil at correct level.
Ideas?
(carpets dry)
You know you want to, you dont realise it yet!
Offline Organisys
  • Old and Slow...
Re: Drinks Water
« Reply #1 on: 06 June 2007, 12:58 »
coolant leak. (hopefully not head gasket!)
look under bonnet, and look up at the engine from below if you can.
likely candidates are water pump, and the platic coolant hose flange from the front of the block.
 :smiley:
any mayo in oil ?
Offline dannythomas752
Re: Drinks Water
« Reply #2 on: 06 June 2007, 13:01 »
Just out of interest how often should you top water up, my water light comes on once a week but do do on average 400 miles a week, so have to top it up?
Offline WhiteMk2Gti
Re: Drinks Water
« Reply #3 on: 06 June 2007, 13:03 »
No mayo.
No damp on block.
Checked all hoses, cant see anything.
Offline *Dubby*
Re: Drinks Water
« Reply #4 on: 06 June 2007, 13:14 »
My corrado was leaking from the cylinder head flange thing, i didn't figure it out until i popped the bonnet after a long drive and saw a tiny bit of steam.....
The flange itself should only cost about a tenner and is mega easy to change, i'd try that first and see if it cures the problem. Apparently they are prone to cracking (although mine was fine, it had been sealed with silicone instead of an o ring, which was the issue!!)
Jeeeeeeeeeeeeeeeeeeeeeeeeep
Offline Organisys
  • Old and Slow...
Re: Drinks Water
« Reply #5 on: 06 June 2007, 20:56 »
If you have no luck finding a leaj yourself, take it to a local garage and get the coolant system pressure tested.
Offline WhiteMk2Gti
Re: Drinks Water
« Reply #6 on: 06 June 2007, 23:32 »
Had the car up on ramps doing the exhaust and noticed water leaking from floor pan.
I gather thats the heater element fooked then.
Offline j_s
Re: Drinks Water
« Reply #7 on: 07 June 2007, 17:09 »
Sounds like the matrix yes.
Cheap enough to replace if you do it yourself, quite a pain to do it though.
James
Offline slyp98
Re: Drinks Water
« Reply #8 on: 07 June 2007, 21:52 »
had very same symtoms white , i had a bad coolant flange too replaced it , still leaking ???? i got a bottle of rad flush , (it does what it sayes on the tin) and after that put a bottle of rad seal in and touch wood nadda not a drop since march , 145 miles per week give it a go if your unsure about the matrix its gonna cost 15 euro max sorry atenner ha ha  :grin:
Offline moonsta
Re: Drinks Water
« Reply #9 on: 07 June 2007, 22:08 »
 take the expansion bottle cap off and shake it,you should be able to hear it rattle inside.if not it is shagged as the valve inside is jammed open and will let the water out when the pressure builds up.if it has done this the water will run down the chassis leg and under the car and rip out.original caps are black in colour,replacement one are blue.cost about £4:00. let us know......joe
Drives '96 Polo 6N and '85 Mk Golf Gti...
