Author Topic: Injector wiring  (Read 854 times)
Offline Maltloaf
Injector wiring
« on: 04 June 2007, 14:48 »
Hi,
I am in the process of building up a new engine (2e) to put back in to my 8v gti (pb, digi), it was all going so well but then I noticed that the wiring loom for the injectors and worn away and needs replacing.
VW have said it could take several weeks to get another. Does anyone know if this needs to a certain resistance or could I use another connector from another wiring loom and just solder in the replacement?
Any help appreciated.
Matt B.
Offline EsSeX dAn
Re: Injector wiring
« Reply #1 on: 04 June 2007, 16:01 »
i wouldnt hace thought it would matter really because all it does it tell the injector to fire and when to do nothing.have you tried going to a brekers to get a used one?would save a lot of aggro with cutting and soldering and the rest of it
i think i love you.....
Offline Maltloaf
Re: Injector wiring
« Reply #2 on: 04 June 2007, 16:15 »
I have tried asking a couple of breakers but they want to sell the wiring loom with the injector rail or a whole engine and are asking for more than the £33 from the dealer.  :sad:
I have found that http://www.vehicle-wiring-products.co.uk/VWPweb2000/connectors/connectors.html sell a connector that should do the job, hopefully.
Offline Simpson
  • one day il learn
Re: Injector wiring
« Reply #3 on: 20 August 2007, 21:32 »
surely you can cut a connector off another car? or replace the bits f wire that need doing, i have a spare 90 spec loom if you want any bits of that still?  :smiley:
i must buy a new car!
Offline Maltloaf
Re: Injector wiring
« Reply #4 on: 20 August 2007, 21:46 »
This was quite an old post m8. I got one from the dealer in the end cos I couldn't get to any breakers and needed the car ASAP.
I am quite glad I got a dealer part as it has a sort of heat sheild on it which is handy when running a S/S manifold.
Offline Simpson
  • one day il learn
Re: Injector wiring
« Reply #5 on: 20 August 2007, 23:07 »
yeah i noticed after i posted lol, i have been quite bored today as you can probably guees, glad you got it sorted.  :smiley:
