Golf mk2
cold air blowing hot
Topic: cold air blowing hot (Read 788 times)
Nathan
GTI forum regular
31 May 2007, 12:12 »
Hi
I have a mk2 Gti 16v 1990. I can only blow hot air through the vents, no matter wheather I have it on hot or cold it comes through boiling! Does any one know how I might be able to solve this problem.
Thanks
Nathan
fused
Here all the time
Re: cold air blowing hot
31 May 2007, 14:04 »
Sonds like it could be a physical connection has broken that goes from the centre console to the heater matrix. If it's the same as min ('90 gti 8v) if you remove the centre console (see haynes) then trace the wire controls from the dash to the heater matrix.
*tell*
31 May 2007, 21:35 »
it sounds like the by-pass valve.
replaced mine 6 months ago
g.s.f had one
Golf mk2
