Author Topic: leak from dizzy..  (Read 2672 times)
Offline rowlers
  • I'm back - MK7 GTI
leak from dizzy..
« on: 28 May 2007, 13:29 »
Been aving a good luck and it looks like the oil leak is coming from where the dizzy bolts to the head. There is no oil at all in the dizzy cap.
Is there a o ring in between the head or where the dizzy joins on the cam?
Or will a bit of silicone sealent on the mating faces sort it?
Offline Gambit
Re: leak from dizzy..
« Reply #1 on: 28 May 2007, 18:33 »
there is a big O-Ring that seals the dizzy into the head. whether u can buy a new one on its own i dunno
Offline rowlers
« Reply #2 on: 28 May 2007, 19:02 »
is that the one that you have to strip the dizzy to fit?
I've had a look on etka but can't find anything, I seem to recall some O rings left over from my HG set :rolleyes: :rolleyes: :rolleyes:
Offline Dub-77
  • Dub again MK1 Golf Project
« Reply #3 on: 28 May 2007, 20:54 »
Lee I had the exact same problrm with my dizzy leaking oil and I fitted a new seal which i too had left over from the H/G set but still pi##ed oil out so i got a small amount of sealent around the seal now seems to have sorted it 4 now  :smug:
The seals are not available from GSF but they are from VW at about £7 each  :undecided:
Darren
Show me a man with a tattoo and i'll show you a man with an interesting past :wink:
Offline Gambit
« Reply #4 on: 29 May 2007, 12:01 »
no its the outer seal on the dizzy
if it was leaking oil into the dizzy cap then its a strip down job to replace the inner seal
Offline tom26
  • team chumpy.
« Reply #5 on: 29 May 2007, 17:19 »
You can get a dizzy from a stealer for about 100 quid on exchange for your old one, if you've had an oiley one for sometime you should notice a small increase in performance for fitting a new (or re-furbed) unit :smiley:
or check ebay as they is a chap that sells new ones on there! they normally go for about £70.
Offline rowlers
« Reply #6 on: 29 May 2007, 18:11 »
anyone know the part number?
I'll have to get one ordered!
« Reply #7 on: 30 May 2007, 13:25 »
you can get a new seal from VW, wont cost a lot.  The later ones have an o-ring round the base where it fits inside the block and early ones just have a gasket around the mounting face.
Offline rowlers
« Reply #8 on: 02 June 2007, 20:07 »
whipped it off today..
there is what looks like an indent? where an Oring is meant to be.
Lots oil oil dropped out when I pulled it off (ohh err missus).
I have gone through etka but I can'y find an o-ring seal for this??
« Reply #9 on: 03 June 2007, 10:56 »
What year/car is it?  I've seen on an old one it had a similar groove as the newer dizzy, but you couldnt get a seal into the old one as it had a ridge, it had a gasket round the top instead.
The o'ring is listed under electrical -> ignition distributor
1st you look under 'distributor versions' and figure out what number yours is, then look under ign distributor and check the o'ring or seal, and look at what seal part # is listed for your dizzy number :)
For example:
026 905 261 is listed for a Digifant 8v dizzy :)
« Last Edit: 03 June 2007, 10:58 by rubjonny »
